I was tempted by fleabay but immediately lost interest when I saw the shipping costs. I never see any piston drives this side of the pond for reasonable prices.
I agree! To me, it is a major breakthrough to have a clip solution for the EX11.2
I sent you a PM, maybe I can help reshipā¦
Update on battery and output curve.
Im using a protected 16340, and am intentionally running it down to determine when its protection will trip. So far the cell is down to 3.5v and max output is down to 175 lumens (reaches 230 lumens on a fresh cell). The firefly level is now less than 0.005, since I cannot read it on my meter (on a full cell 0.4 lumens). Suffice to say the light goes as low as I would ever need, and higher than I usually use.
So far, using maximum briefly has failed to trip the protection circuit on the battery. Im very happy about the way the light is operating.
I was thinking the same thing! The box is way bigger than it needs to be. 12*19*9cm. Itās really just the light and a lanyard so a thin box is all you need.
Thanks for the offer guys. As tempting as it is Iām going to resist. Maybe if they were from the D series I could be tempted!
What a nice collection you have there jon_slider
Great lights, congratulations !!
thank you!
Im very fortunate to have three of a kind
and the box has room for a few more lights
I think that box should be used exclusively for more PD lights!
What else came in the box? Looks three times the size of my normal D10 box.
Someone needs an intervention lol. I had that many nitro rc airplanes at one point though, so I canāt really judge.
OK, I will take Five D10 pleaseā¦ lol
The box is full of foam, plus a lanyard
please NO!..
some of the lights you see in the box, are in transition to adoption
also true for my accumulation of three Winter Editions, two are modded for adoption to a loving homeā¦
Im happy to keep them if there is no interest, but would be happier to buy more for distribution to people that will appreciate them.
it is not every day that a ramping light that can be modded to Nichia easily, comes alongā¦ get em while you can
Nice collection Jon!
I did some heavy searching. CRX did a CuTi piston drive. Cereal Killer did some Anduril mods to D10s ( 1 , 2 , 3 ). I feel like I remember someone mounting a switch inside the spring of a light to make something with similar spirit to piston drive: and found it
Public Service Announcement
Stop the Presses!
I have discovered a wart on my sweetheart, the morning after.
The 11.2 driver is unregulated, so the output drifts, sometimes just 20, other times 50 or more, depends on temperature of the light, and how high an output level is being requested.
I only noticed this lumen drift because I have a light meter. It is not easy to see with naked eyes in actual use because our brain has a wide lumen range tolerance, and also we change lumens on target often, based on how far we hold the light from the target.
here is a more extreme drift example, way more than 100%
EX11.2 using CR123 shows regulated output
I only recommend buying 11.2 versions if you intend to use Primary cells
By contrast the 10.0 driver has rock steady output regulation on both CR123 and 16340 (LiIon is not brighter than Primary). I strongly prefer the regulated 10.0 driver.
It was a fun ride
Looks like Ive got a pile of lights to loveā¦
First world problems.
So is this just above 3v then? I wanted to mod the d10 that I lost so now I guess I will mod the ex11 driver (and an xp-l 4000K swap). It would be interesting to see if I can fit a tiny buck driver that could deliver 1-2A cc and just PWM it. Itās not a lot of current but I want a butter smooth ramping task light. Should be more than bright enough.
yes
I believe the drifting only happens above 3.2 volts (as with LiIon)
the EX11.2 works great on CR123ā¦ very stable, no weird drifting
here is another reason to prefer CR123 over 16340 in 11.2 drivers
avoiding sudden darkness:
I ran a 16340 down until protection tripped
that happened when the max output had decreased to 110 lumens (max was 225 lumens w an sw30), and the protection in the battery tripped at 3.2 volts, creating sudden darknessā¦
A CR123 is the right āOctaneā fuel for the 11.2 driver
For short use itās probably not a big deal. But, if you want it to be more stable and still use a rechargable Tenergy makes a 3v cell. I just tried one, works fine but obviously not as bright. I had been using them in my Extreme. Which I am now thinking of selling lol. But that light does have the potential to be a 16340 pocket rocket, a lot more body for cooling. I just donāt like the tactical look. I donāt go out hunting people on weekends.
good call
also less bright on CR123
I dont need more than 100 lumens, on a light I use mostly indoors.
handy as a glovebox light too
Iāll take it ! How much for the box of lights :heart_eyes:
since I started hanging around here
you guys have cost me some cash
I donāt know if I want to compliment that collection or build you a box with some sort of separators
Nice testing
yes,
Protection is important
I wonder if these plastic bottle preforms could be found in a suitable size
Slightly less elegant than I had in mind but still effective
