I would avoid buying from Kaidomain for the moment until I get a successful reflow myself for testing. The 2mm has a slight purple tint even at 4.5A. djozz is thinking it may have been a bad reflow. It could be an entire batch as all 6pcs have the same issue.
My 30pcs 1mm do the same thing at 4.3A so I’m selling at 3.5A (650 lumens) with stacked 7135 chips
So do you think whoever is doing white flat reflows at Kaidomain is doing a botchy work? @#$%, I have a couple lying around.
Will mount them on an old PC heatsink, set a small narrow beam TIR lens on top of the emitters, and proceed with some testing with my power supply and smartphone as ceilingbounce luxmeter.
I’m not 100% since this is the first time using white flats. I did attempt a reflow, a terrible one, and it was instant purple. It was the same tint but much worse, which feels like that confirmed it for me. It would have been a different story if it was blue but it was exactly the same tint
Ordered some lead solder paste to try again once it arrives.
I believe it is normal. It is quite purple-ish, but the output is close to other pure white WFs I got from mouser. IMO the tint worked pretty good outdoors.
That is very similar to the smaller LEP light with 250K.
But fewer legal issues to use an LED , especially if less than 10 miles from an airport .
Not legal to even use any type of laser outside even with no planes in sight.
If I pay someone to mod a Jaxman Z1 - will I get similar results ?
It would be cool to have a Turbo[4 min runtime ] and a near turbo ( 15 minute run time] Medium high and Low and moon mode
2] Bonus question- what about the twist zoom glass aspherics they use for cheap infrared lights T20 T38 etc?
Are those likely yield good results or too much work to mod for a Pro ?
AFAIK all current handheld LEPs are rated as class 3R or 3B lasers depending on the specific model. Whether that refers only to the laser diode inside, or the whole device is NOT a question many would want to have to sort out in their own criminal trial.
Vehicle mounted LEP arrays wouldn’t have or need anywhere near the same level of collimation either which is certainly a consideration in eye hazard for lights/lasers. This is the only thing I could find in regards to LEPs and aviation use: https://www.faa.gov/pilots/safety/pilotsafetybrochures/media/LaserEyeProtection.pdf
LEP stands for Laser Eye Protection in this case, pretty much the opposite of using the LEPs we usually mean as aviation lights.
LEPs are laser excited phosphors.
Instead of a blue LED there is a blue laser diode.
The light produced by the phosphor is regular white light like any LED, it is not laser light.
Also collimated flasshlights don’t case eye damge like a laser can.
Even though it is near collimated, the cross sectional area is hundreds of times larger than a laser and won’t cause eye damage.
I mean you’re completely right, the question is whether the law will consider something that uses a mirrored laser to create light from a phosphor (and then has multiple lenses to focus that light) anything except a laser itself. Especially with the beam it produces, and whether or not someone could blind pilots with it… it certainly will look like you could to most people. I think the smart thing to do either way would be to not use it near an airport if your areas has laws against lasers in a certain proximity. I’m not even sure the laws everywhere will distinguish between an actual LASER and any light emitting device… just in case someone thought it would be funny to point their 1940s searchlight at a 737 lol.
Do we have close-range intensity numbers to support that? They are hundreds of times brighter than a 5 or 10mW laser.
Look up NOHD, that’s the distance where you can get (termporarily) blinded because your blink reflex isn’t fast enough.
For example a 2W laser with 272Mcd (from wickedlasers) is at like 126m.
Since the beam of a laser is so thin and has such a small divergence, it’s safe to assume the whole beam can enter your pupil, which is 17000cd at 126m.
Not only is a flashlight like a maxabeam (with 12Mcd) far less powerful in the first place, it also has a beam diameter of 5.5” at the head, with 1 degree of divergence, which at 126m would be over 2m diameter.
This is over 3 million square millimeters of cross sectional area.
If your pupil has an area of 3mm^2 then that means that only 1 millionth of the beam intensity is actually entering your eye.
At 126m the maxabeam is 756 candela, so only 0.000756cd is entering your eye.
So that’s like 20 million times less intense than the laser.
If you had a giant magnifying glass and you focused the whole beam from a flashlight into your pupil, then yeah you can get eye damage.
But since the beams of flashlights (even the best ones like a maxabeam) have very large divergence, it’s impossible to cause ocular damage, not enough light can eneter the eye.
Also the maxabeam is far more powerful than any LEP that exists, and has less beam divergence, so it’s a pretty extreme example for comparison.
You’re confusing lux (illumination per unit of area) with candela (peak intensity) Candela can be a single point within the total beam and the surface area that you’re covering with beam of “X” intensity doesn’t matter. If 17,000cd at 126m is rated an eye hazard, then 17,000 (or the significantly higher numbers from LEPs and other lights) at point blank is a hazard too.
If you could theoretically block out 90% of the beam (from a cross-section perspective like you said) of an LEP the cd would be exactly the same (assuming consistent intensity throughout the whole beam, which probably isn’t true to be fair).
