The first/old versions of the E3 are not on sale (at least on Jaxman AliExpress store). You can find “copies”, but not the original is not sold anymore.
The new version, is: Page Not Found - Aliexpress.com
There are no changes in the name, but there are changes in the structure of the falshlight as you can see on the post#1 of this thread
Has anyone replaced the LED on the E3 with an XPL HI? I have been wondering about this, just replacing the the led but keeping the same driver. Would I gain any more output and runtime compared to the nichia? Another thing, does the XPL HI emitter fit in the stock reflector opening?
Hi lg.tech! Welcome to BLF :partying_face:
I just wanted to let you know that XP-L HI emitters will fit well on this flashlight’s reflector! Any 3535 footprint emitter will fit well (XP-G2, XP-G3, XP-L HI, XP-L HD, some Nichias, Luxeon V2, and others).
I modified my light and I don’t have the original driver anymore, so I can’t do a runtime test. But, I guess runtimes on this flashlight will probably depend more on the type/quality of batteries you will use and on the levels you will use than the LED you’ll have on it.
Thank you for the welcome and for your response!
Do you know what size PCB I can fit in it? I’m thinking of getting the noctigon 16mm.
I love this light, I got the nichia 4000k version, but for outside usage it’s fairly weak with this tint. I have an old Nitecore D11 which has a similar output but with a cool white emitter and it’s much more usable, so I thought about putting an XPL HI 5000k on the jaxman E3.
As for batteries I have Standard eneloops, Sony 2400mAh Ni-MH and Efest 14500. I normally just use it with the Sony batteries, runtimes aren’t great with any of them, my old Nitecore D11 has a better runtime.
You can fit a 16mm diameter MCPCB. However, please note that if the Noctigon is thicker than the original PCB, it may leave a small gap between the bezel and the edge of the head where it screws in. You can add an extra o-ring there to maintain it more or less “sealed”.
About batteries, in case you want to use it with 14500, you can take a look at these Vapcell batteries: Test/review of Vapcell ICR14500 1000mAh (Gold) 2018
They have higher capacity than the Efests, and as this is not a high drain flashlight/driver, they can give you some more output and still last for a while.
However, note that Jaxman adivises to use more the Ni-MH batteries than the 14500 Li-Ion.
I guess the 5000K XP-L HI is a great choice, it is neutral white colour and will be good for indoor and outdoor. Also, it will not produce tint shifts under the Jaxman reflector.
Has anyone measured the lumen output on the E3?
One other thing, I have been thinking about how the E3 would perform with a smooth reflector, does anyone know where I could find a smooth reflector for the E3?
I have a Nitecore MT2C and on the lowest level (measured around 38 lumens by reviewer selfbuilt) it’s noticeably brighter than my E3 on the mid level looking at about 1 meter distance.
I swapped the 5700k Nichia for a 4000k SST20 in one of mine. I cracked the lens tightening the bezel and between the MCPCB thickness change and the new lens being thicker the bezel no longer threads down flush. Not a functional issue but disappointing anyhow. Still and excellent 1AA light for general use. Personally I like the LMH for a 1AA light. What UI are you looking for? Are you still with AA or do you want to go li-ion 14500?
Thanks for the info. You cracked the lens because the new MCPCB was thicker, I take it? How thin was the one you put in?
I assumed from your quote that you also swapped the driver. Is that correct?
I’d be fine using 14500 if it gave me access to a better driver/UI. I assume that’s the case because AA lights need a boost driver, right? And that will limit the driver and UI choices?
I’d like an AA/14500 light, as small as possible, with low moonlight modes and a reasonably high turbo/high, and a more customizable UI (Bistro, Crescendo, or even guppydrv). I’ve been searching for hosts to do a driver swap like this. Does what I’m looking for exist?
I’ve also investigated filing down a 15mm Mountain Electronics board to fit into a Lumintop Tool AA and going to 14500. Not sure I have the tools to file it down, but I’d try!
Will I end up burning out a 219b on turbo with a FET driver? Also, could I sneak in a 1.5mm copper MCPCB? Or am I stuck with aluminum at 1mm? Perhaps that extra half a millimeter is why buck91 ended up with a cracked bezel…?
Button can work if u use button top battery and hard/long spring on the tail.
Use copper mcpcb with dtp and reduce thickness to 1mm with sandpaper.
When using spandard mcpcb (1.5-1.6mm) you will just have a gap between the bezel and the body.
If you use a low current cell, the 219b might survive the turbo.
I did not swap the driver, I like the LMH of the stock. Plus its AA/14500 capable so I was happy. Yes, the new LED was on a thicker MCPCB and I didn’t realize I was tightening the bezel too hard cracking the lens. Definitely my fault and now the new lens is thicker too resulting in a noticeable gap (though using some thread sealer on the bezel threads makes it a aesthetics only issue.)
Ok, cool. If I end up going the spring route, using a small spring on the driver would work, too?
I’m a bit confused on how a thicker MCPCB would leave a gap. Wouldn’t it be an issue of less space, not more? I’m clearly not conceptualizing this properly. Thanks for taking the time to explain.
