It’s not too hard for me to do a video on a very specific menu function for NarsilM or Anduril. I think the video above is close enough to figure it out.
If anyone needs a very specific video, let me know.
I just watched it again recently and got to thinking… is there anything Cooler (McQueen) could’ve done differently in the motorcycle chase scene? I was thinking he should’ve broken into that small barn and hid with the motorcycle until very early morning the next day to make a run for Switzerland.
So the question — what do you think Cooler could’ve done differently to effect a successful escape?
Thanks. I figured I’d ask it here, since this is the “no stupid question” topic. I agree, it’s a great movie… and I’d had about an 8 year gap on seeing it. I did fast-forward through parts. When you’re familiar enough with a movie & watching it alone, no point in having to “wait” for the parts you really want to see.
I was thinking similarly, to hide in that barn, sneak over to the wall-o’-wire and try to get through it with the ’cycle late at night, when no one was around.
Always wondered how Stonn (Lawrence Montaigne) got caught. He was good to go on the train, and then…??
You might try asking M4D M4X. I think he has a 219b FW3A and he has a lot of 18350 cells. Last I heard it was a bit iffy with high drain 18650, but the 18350 might be okay. He might know for sure.
Does speed of charging affect li ion battery life, performance, etc? The other day it took my nitecore D2 charger about 5 hours or so to charge one 18650. Later that day I charged my Bosch compact drill li ion pack (which looks like 3x 18650s) on it’s “30 minute” charger. So it charged 3 18650s in—you guessed it—30 minutes. I did not have a way to test capacity. Is that healthy for a battery to be charged that quickly? If there’s no problem with fast charging, why don’t we see more of it with chargers and flashlights.
Separate note. I wish my LT1 charged quicker. (How much would usb-c to usb-c improve this?)
High amp chargers are expensive and "rapid chargers" must be high amp. Nitecore chargers in general are cheap, least cheap in terms of highest rated amp charging, they are generally overpriced in the retail market - you pay for the nice packaging, etc.
The 20R normal charge rate is 1 amp (2 hours) while the rapid charge rate is 4 amps (30 mins). The datasheet doesn't get specific about the rapid charge rate effecting the battery's lifetime and performance, least that I could find. Usually it detracts from the overall effective lifetime. Batteries lose capacity and add resistance over time, so all depends how fast or slow the degradation occurs at.
They say in the datasheet:
7.10 Cycle life With standard charge and maximum continuous discharge. Capacity after 250cycles, Capacity ≥ 1,200mAh (60% of the nominal capacity at 25℃)
So, how does it perform using rapid charge? They don't seem to say, but guaranteed it's gonna be worse.
