Thank you for the welcome and for your response!
Do you know what size PCB I can fit in it? I’m thinking of getting the noctigon 16mm.
I love this light, I got the nichia 4000k version, but for outside usage it’s fairly weak with this tint. I have an old Nitecore D11 which has a similar output but with a cool white emitter and it’s much more usable, so I thought about putting an XPL HI 5000k on the jaxman E3.
As for batteries I have Standard eneloops, Sony 2400mAh Ni-MH and Efest 14500. I normally just use it with the Sony batteries, runtimes aren’t great with any of them, my old Nitecore D11 has a better runtime.
You’re welcome
You can fit a 16mm diameter MCPCB. However, please note that if the Noctigon is thicker than the original PCB, it may leave a small gap between the bezel and the edge of the head where it screws in. You can add an extra o-ring there to maintain it more or less “sealed”.
About batteries, in case you want to use it with 14500, you can take a look at these Vapcell batteries: Test/review of Vapcell ICR14500 1000mAh (Gold) 2018
They have higher capacity than the Efests, and as this is not a high drain flashlight/driver, they can give you some more output and still last for a while.
However, note that Jaxman adivises to use more the Ni-MH batteries than the 14500 Li-Ion.
I guess the 5000K XP-L HI is a great choice, it is neutral white colour and will be good for indoor and outdoor. Also, it will not produce tint shifts under the Jaxman reflector.
The Noctigon MCPCB is 1.6mm thick. https://intl-outdoor.com/led/xp-l-hi/noctigon-xp16-cree-xp-l-high-intensity-v4-3c.html
Looks like I’m gonna have to wait a little while before I can try this. The shipping estimate for me is over 3 months due to the pandemic.
Hum, you can try other sources: 2.34€ 66% OFF|XPL HALLO V2 1A / U6 3A / U6 4C / U4 7A LED|cree xpl|cree xpl hixpl hi - AliExpress
It is not a Noctigon, but it is a DTP MCPCB (Direct Thermal Path). It is sold by Convoy Store, run by Simon Mao.
You can ask him if he is currently shipping to your place.
Or you can check other sources, such as Kaidomain.com or their AliExpress store (7.25€ 5% OFF|Cree XP L HALLO 10W 3A 1095 Lumen 6500K 5000K 4000K 3000K SMD 3535 LED Emitter auf KDLikter DTP Kupfer MCPCB Taschenlampe DIY|led emitter|neutral whiteemitter led - AliExpress)
In any case, it is better to check with sellers before ordering.
That’s funny, I just talked to Simon yesterday about ordering a S2+ but unfortunately I’ll have to wait.
Hi Jaxman, liking the look of your new X2. Any chance of making the host available on your AE store? I would love an E3 host as well!
Has anyone measured the lumen output on the E3?
One other thing, I have been thinking about how the E3 would perform with a smooth reflector, does anyone know where I could find a smooth reflector for the E3?
I have a Nitecore MT2C and on the lowest level (measured around 38 lumens by reviewer selfbuilt) it’s noticeably brighter than my E3 on the mid level looking at about 1 meter distance.
I’m thinking of getting a Jaxman E3 to mod. What size driver will fit? And what did you swap it to?
I’d like to put something with better UI in there as well as swap the LED.
I swapped the 5700k Nichia for a 4000k SST20 in one of mine. I cracked the lens tightening the bezel and between the MCPCB thickness change and the new lens being thicker the bezel no longer threads down flush. Not a functional issue but disappointing anyhow. Still and excellent 1AA light for general use. Personally I like the LMH for a 1AA light. What UI are you looking for? Are you still with AA or do you want to go li-ion 14500?
Thanks for the info. You cracked the lens because the new MCPCB was thicker, I take it? How thin was the one you put in?
I assumed from your quote that you also swapped the driver. Is that correct?
I’d be fine using 14500 if it gave me access to a better driver/UI. I assume that’s the case because AA lights need a boost driver, right? And that will limit the driver and UI choices?
I’d like an AA/14500 light, as small as possible, with low moonlight modes and a reasonably high turbo/high, and a more customizable UI (Bistro, Crescendo, or even guppydrv). I’ve been searching for hosts to do a driver swap like this. Does what I’m looking for exist?
I’ve also investigated filing down a 15mm Mountain Electronics board to fit into a Lumintop Tool AA and going to 14500. Not sure I have the tools to file it down, but I’d try!
17mm driver. Mcpcb must be 1mm thick.
Rad. That gives me a lot of options with the driver. Thank you!
Could I put a DrJones H17Fx in it and just use 14500? Or a MTN-17DDm?
I’d probably be using a 219b so I’d end up limiting the FET usage but want a better UI.
Yes, but I recommend using short spring on the driver.
Or a button instead of a spring, perhaps?
Will I end up burning out a 219b on turbo with a FET driver? Also, could I sneak in a 1.5mm copper MCPCB? Or am I stuck with aluminum at 1mm? Perhaps that extra half a millimeter is why buck91 ended up with a cracked bezel…?
Thanks for all your help.
Button can work if u use button top battery and hard/long spring on the tail.
Use copper mcpcb with dtp and reduce thickness to 1mm with sandpaper.
When using spandard mcpcb (1.5-1.6mm) you will just have a gap between the bezel and the body.
If you use a low current cell, the 219b might survive the turbo.
I did not swap the driver, I like the LMH of the stock. Plus its AA/14500 capable so I was happy. Yes, the new LED was on a thicker MCPCB and I didn’t realize I was tightening the bezel too hard cracking the lens. Definitely my fault and now the new lens is thicker too resulting in a noticeable gap (though using some thread sealer on the bezel threads makes it a aesthetics only issue.)
Ok, cool. If I end up going the spring route, using a small spring on the driver would work, too?
I’m a bit confused on how a thicker MCPCB would leave a gap. Wouldn’t it be an issue of less space, not more? I’m clearly not conceptualizing this properly. Thanks for taking the time to explain.
Gotcha. Thanks for the info.
Jaxman uses a standard 16mm mcpcb with a thickness of 1mm in thier flashlights and they designed the flashlight for this thickness. They don’t sell it as a host, that’s why they probably did it. I received 1mm mcpcb with the set when ordering the host version.
I think the Convoy T2 is a better choice for us (modders). Think about it too.
Ahh, OK. I’ll check out the T2, as well.
It looks like a T2 takes a 17mm driver as well? If I put in one of those two drivers I suggested into a T2, I’d be going to all 14500, and it would work fine, correct? And the T2 takes a 16mm DTP MCPCB fine?
Re:219b in a T2 with a FET driver (as I’m planning), so you think my Keeppower 14500 1000mAh puts out just too much at 4A continuous to not fry the emitter? Perhaps I should get a Vapcell 3A?
