glad you are able to fit protected 18350 in your 2019 RRT-01, and that the gap is the same either way…
sounds like different copies of the 2019 RRT-01 have different size gaps with protected 18350…
it also sounds like the batteries themselves vary in length, as my 34.7mm vs your 35.2mm unprotected 18350 measurements are clearly different.
In any case, I think we all agree that the 2019 RRT-01 does work with Protected 18350, and does not expose the O ring, even though it does show the brass…
I asked Jetbeam about the hole in the control ring and they said this: “The control ring hole is for put grease into it. It’s not for tritium vial.” Can anyone explain what that means? They don’t need a hole on any other version of the light for the grease. Will this compromise waterproofing, or was that part of the design always on the outside of the waterproof barrier? Will this make it easier to regrease the ring down the road without diassembly?
The control ring has always been open to the elements. Over time they do get dry or gritty and needs cleaned and refreshed.
Grease tends to shed water so it helps a little being water resistant…
there is an O ring that seals the center of the control ring assembly, so even though water could get between the control ring contact faces (where the ball bearing rides), the water cannot get inside the pill.
here are some examples of the O ring seal on various models of magnetic rotaries
red O rings
black O ring on V10r Ti, which is similar to the 2019 and 2020 RRT-01 configuration (ignore the arrows, they are part of a past discussion of where to put grease)
plus locktite that seals the threads. (this is a V10r, also similar assembly as the 2019 and 2020 RRT-01
Do I need to email Neal about this or something? Looking at his website I can’t find just the extension tubes listed. I have 3 2019 light’s i’d love 18650 extension tubes for!
Received from Neal 2020 rrt01. The extension tubes came as part of the stock packaging so i think mainly available with the light??
Also pleasantly surprised by grey anodized. If i were a rocket scientist i could post a darn picture or two.
Also was sent xpl instead of nichia which made the decision whether to emitter swap for me.
Bezel opens to reveal mcpcb ready to extract and swap emitter. That sounds easier that opening older ones? I’m no expert though so don’t exactly know what I’m yakking about…ha ha, my phone put that word in for me… yakking
I never did get it to work either. Signed up for free Imgur and been uploading pics there for a few years.
It gives you a link to post your hosted pic.
I see your link now. Just click the insert pic icon in blf and place your link there and set relative width to about 70%.
If someone owns 2019 and 2020 versions: It would be very nice to verify that the new battery tube fits the old head. I presume it does since the extensions can connect both parts, but someone here said it won’t work. I intend to ask Jetbeam for a seperate 2020 tube to replace the old one, which has a thickness of only about 0.5 mm. Not interested in the new head. Also, does this combination, if it works, finally take protected 18350 cells?
I opened the 2019 head exactly this way and did an emitter swap. No need to open the head. SWM V11R needed this, but not the Jetbeam. Space is limited to unsolder the MCPCB though, but it works.
It should take a protected cell. The new tube is longer and the cell it comes with is an 1100 mAh 18350 with protection circuit and charging board with USB circuit on top. This longer cell fits fine and I suspect any 18350 should fit.
I’m not sure this will fix any durability issues though. I don’t have a caliper to verify, but the thin portions of the 2020 lube look very similar to the 2019 tube.
Looks like it’s time for me to try to order some replacement drivers from Jetbeam. Opened up my modded TCR-01 triple today to take a look inside at the emitters. Driver wires torqued when I unscrewed the bezel and then shorted.
I was careful to only grip the portion of the head above the ring when unscrewing the bezel. But unfortunately the optic was stuck in the bezel and when I unscrewed the bezel it turned the optic which caused the star to turn. Oops! I had a cell installed at the time too. I disassembled the driver sandwich to install new wires, but a couple components broke along with trace where one of the driver wires connects. This driver has had it.
