Okay, if you want to sell a light to The Muggle that takes AA-format cells (1.xV or 3.xV), you need to dumb it down somewhat to prevent those nice free Amazon returns. Howbow…
3C nothing (ie, anything beyond 2C requires minor determination to get there)
4C lockout
5C momentary.
Unscrew/Rescrew to “reset” from any any any any any mode.
On powerup (including unscrew/rescrew), blink out battery voltage (X.Y volts normally, or 1-4 blinks for the developmentally-disabled).
Ie, no (other) blinkies.
Unless someone buys 10 of ‘em to stick on his kid’s b’day cake, who really needs candle-mode in an AA-format light? Or lightning mode, or even plain ol’ irritating strobe?
People don’t want ¼” drills. They want ¼” holes. Weirdos like us might want to be able to control-alt-tripleclick to get to cuttlefish mode, but the typical DD flashlight buyer would stumble upon that mode and sent it back just for spite. They’re used to their simple Mags and Dorcys and whatnot, and tossing ’em the keys to a 747 is just asking for trouble.
Sorry, people – if it doesn’t work well on AA NiMH, I’m out.
I’m legally blind, and the way I avoid confusion between cells with different nominal voltages is to decree one voltage per size. That way, I can’t fry anything that uses 1.2V / 1.5V cells by putting 3.7V Li-Ions in it by mistake.
There’s so much stuff that uses AA or AAA that those have to be the choice in that size. There will never be Li-Ion 10440 or 14500 cells in my stuff.
(When I’m using Li-Ion, it’s always 18650 or 26650.)
Nice. Looks like the pad layout is different than the key that I bought for my Emisar lights. Is this layout available to purchase anywhere? Or is there a way I can easily adapt it?
Also, for whatever it’s worth, I tested the voltage of my kids SP10S when the Ladda AA in it stopped working, and it was at .897. So thereabouts is when the boost driver stops working.
As far as I understand it, if with the modification Lexel has proposed, the driver proves to be capable of running Anduril, the worry about needing extra time or money to make it 1.5V and 3.7V compatible is moot.
If the desire is to get an Anduril 14500 light as soon as possible, I think that can be accomplished already using a Texas Avenger design (I don’t know if Texas Ace sells them assembled, but Lexel has a variant) if you have a host that accepts a 15mm driver and are comfortable doing a driver swap.
To my recollection, Anduril is designed for the ATTiny microcontrollers, which require a higher voltage to run. The last discussion I saw was that the microcontroller would have to receive boosted voltage from AA/NiMH just to turn on, and then it could do its thing. Implementation of that (or another) solution is over my head
Lexel has two coils on his board. It appears one drives the logic circuitry while the other drives the power LED. The coil that drives the logic circuitry can boost independently of the LED coil. Because the logic circuitry requires so much less current to run vs. the primary LED, the microcontroller will have power right up until the very end of the battery life. The primary LED may not be able to run, but the brains of the operation will get the juice it requires.
I suggest smooth diamond or square knurling for the body instead of currently rought,will be more nice to hold and simple ramping version similar sp36s
