Hello BLFers,
We are developing a TNO flashlight( tactical and outdoor), how come? It is a flashlight with tactical OS (Operation System) and outdoor OS, controlled via a side switch and a rear switch, check out the look of it with the pictures below
Design:
User Interface:
Tactical OS
ON/OFF: Click on the rear switch to turn on or turn off the flashlight.
Instant Turbo: From off, single tap on the rear switch to activate Instant Turbo, and further click to turn constant on Turbo.
Instant Strobe: From off, double tap on the rear switch to activate instant Strobe, and further click to get into constant Strobe.
Output levels: From on, click on the side switch to swap between Turbo <=> Low, designed to be always turned on Turbo. Double click to activate Strobe, Triple click to activate SOS, single click to return to constant on.
Sum up( Always to turned on Turbo, Instant Turbo, Instant Strobe, switch between Turbo-Low, Turbo-Strobe).
Outdoor OS
Memorized output startup: From off, single tap on the rear switch to activate the output level on which it was turned off last time, and further click to turn constant on that output.
Moonlight startup: From off, double tap on the rear switch to activate instant Moonlight, and further click to get into constant Moonlight.
Output levels: From on, click on the side switch to cycle through Turbo-Low-Med-High. Double click to activate Strobe, Triple click to activate SOS, single click to go back to constant on.
Sum up( Memorized output startup, Moonlight startup, Hidden SOS).
OS switching
From ON, press and hold the side switch for 3s to switch between Tactical and Outdoor OS, flashes 3 time to turn on low for outdoor OS, while flashes 1 time to turn on Turbo for tactical OS.
Instant tactical OS: From OFF, press and hold the side switch and click the rear switch to turn on Turbo on Tactical mode.ââYou donât need to go through a complicated operation.
Parameter
You are welcome to comment below to talk about how you think about this flashlight.
