“Between” is almost always a compromise that tries to do both but does neither very well.
Even just going outside for a few minutes, I’ll take my E03 with diffusion film as a flooder, and ’micro if I want throw. Anything else is one of those lousy compromises.
I’m in the same boat. I was very tempted… but I’d like to see it offered with other emitters. I don’t need 10k lumens on turbo, especially since it doesn’t last but a handful of seconds.
The multi-emmiter light is just like a reflector light, just with 3 small reflectors instead of a single bigger one. So you do have a hotspot. It’s a smaller reflector so the hotspot is bigger.
The only reason it’s flood would be better is that it’s brighter. I don’t think there would be a big difference in the angle the light comes out.
You can see a similar comparison here with the EC01 and EC03. The EC03 has a bigger hotspot and is brighter. This makes its spill light brighter as well.
I have a question for those who sand down TIR optics to fit in lights because I sanded mine down to fit into a D10 and it resulted in having a donut hole. How do you guys remedy that or is it now a lost cause?
Hmm, I’ve never heard of that happening. What optic was it, a narrow angle one? I tend to use wide angle ones for close up work. Those usually have a pebble texture finish. You might try raising or lowering the optic to see if that changes the focus.
It was a 60 degree pebbled lens. Similar to this one. . There isn’t a lot of clearance to raise/lower the optic. I wanted to leave the glass lens there since I made the mistake of shaving the diameter a bit too much and is not making a prefect seal in terms of waterproofing.
We have the same mods (I use the glass lens in my D10 also, but no centering ring), but I don’t have a donut hole pattern. You removed the white part, yes?
Maybe your particular optic is the issue. If your in the USA you might try buying this one. A little bit of filing is all it needs and the beam is perfect in my light.
If you’re outside the US and it costs too much to buy from Mountain Electronics, you might just try buying a different brand of optic from AliExpress and see if that fixes the problem.
Yeah I removed the white part, maybe it is the optic. I guess I’ll try to experiment on it since it’s good as broken anyways. Thanks for always answering my questions here JasonWW. Really appreciate it.
Are you both using the same emitter? If an optics behaves well with XM-L2 in particular, it’s often not great with other emitters (in my experience anyway).
I did not consider the emitter I was using. I’m using an SST20 in mine. Kinda already destroyed it last night sanding it all around making it a frosted optic so I can’t try on another emitter. An undesirable method but it works, no donut hole anymore.
