Just as I thought when I compared to KD’s mcpcb. Confirms that mine aren’t dtp for the Osram red, I’ll reflow one to the KD board. It’ll be great if I can drive them harder.
They’re currently on 3535 so using 3030 may improve too
I was going to buy Convoy’s newly added 3030 boards but can’t tell by photo if really dtp?
That “HX” from AE (YinDing) seems off. What’s with the exposed gray portion next to the die? Also, their other white flat listings have unusual markings on the surrounding white areas of the package.
Any specs?
The right one seems to be the CULPM1;which is the higher current version of CSLPM1.TG. There aren’t too many manufacturers around which use them
Both flashlights are the same model: Manta Ray S21 with Osram NM1 LED (supposedly) - one has a gray bar, the other does not. The Manta Ray S21 uses a 2.8Amp (7135x8) driver, but the UI is sort of different (it seems to be related in terms of configuration as the Convoy C8+ SST40 ‘ramping’ driver version).
In my other set of Osram NM1 photos, one is a Wainlight C8S-G with Osram NM1 LED (no gray bar), the other is a Boruit C8 with Osram NM1 LED (but has a gray bar). The Boruit C8 and the Wainlight C8S-G look very similar (they use the same flashlight host as the Convoy C8+, but place an Osram NM1 LED and both seem to use a driver that is similar to Convoy’s 5/3-mode group driver (also 7135x8 or 2.8Amps).
