I don't think the spec temperature means anything. It is just a setting at which they measure performance. Maybe some people complained that Cree was evaluating their LED's at room temperature when, realistically, the LED is going to get hot very quickly and it would be more realistic to measure the output when the LED is hot. The datasheets allow you to generate numbers at any temperature you want, it's just the default (100%) value is at 25 degrees for the XP-G while for the XT-E it is 100% at 85 degrees.
So runtime should be amazing with this thing, huh?
Exactly equal to any other LED driven at 1 Amp. An XML, XPE, XRE or XPG driven to 1 Amp would have identical run-time**.
**Assuming a linear driver where Vf is irrelevant. A switch-mode driver would vary the run-times a little according to differences in LED Vf.
PPtk
Correct, and XT-E is 114% at Tj=25 degrees.
I wonder why they changed the temperature? Could it be that the carbide base of these chips doesn't transfer heat as well so they expect them to actually run hotter?
On the contrary, XT-E has a thermal resistance to the base = 5 degr./W and the XP-G has 6 degr./W
I think they started binning XB-D and XT-E at 85'C as a new policy. You can easily make a verification test at that temperature. It is more difficult to set up a test at the north pole
Got my XT-E drop-in from KaiDomain today. I love that it has 3 modes using the NANJG AK-47A driver. The drop-in has a smooth reflector, but the beam has a definite yellow center. The edge of the hotspot is a little green or yellow. Not sure if Cree will be able to work this out.
Here's the LED:
That beamshot looks a lot like the LED I received.
I wonder if manufacturers like Eagletac suffer from the same problems with their D25 series.
I tried some 3000K warm white XT-E in a homebrew 4x Mag mod that I'm not done with yet. I tried a variety of reflector shapes, sizes and textures and even a few optics. The one and only thing I tried that gave pleasant uniform color (instead of banana-berry swirl) were Ledil Boom Spot 20mm microfaceted reflectors. I'd venture a guess that a Fraen 34mm microfaceted reflector might look good as well, but I don't have any spares or room for them in the light I'm building.
Remember when the XMLs first came out we got horrible color change like that also. Hopefully quality control will come up after a while and we will get more even color dispersion
I would love to see a outdoor beamshot to see how the color of the beam translates to a multi colored environment.
but from what this thread has said, i think it would be better to apply the $8 one of these costs towards another xm-l drop-in.
I got one too and while I was a little disappointed by the beam it produces, I don't think it's all that bad. To me, the beam is somewhat similar the what you would get from an Edison Opto Edixeon LED which like the Seoul Semiconductors P4 and P7 also uses a Cree die (EZ1000?). Anyway, if you're a flashaholic and you don't mind having something different in your collection, still not a bad thing to have an XT-E P60 dropin in my opinion. I find the mix of yellow and bluish-white tint of the beam as a hybrid giving you cool and warm white all in one beam.
Nice beamshot, thanks!
IMO, the beam is a bit more ringy than in XP-G.
My beams hotspots centre has a bluish hue, then turns to yellowish. -corona is less yellowish and spill has some hues of purple.
Still, could be worse. To my eye this is between 3B/3C and A1 XM-L´s when considering warmness of the beam.
In fact, this is IMO far better than most of my previous XP-E R2´s, which were almost all purple or bluish.
About the same I see here.
I'll try to get some outdoor shots tonight. I took it out last night and the yellow dot is noticeable outside, but I was pretty impressed with the throw of the drop-in. I was comparing it to a couple of other lights and it was doing quite well, but I need to compare it to a cool white XP-G to be fair (I was comparing it to some neutral XP-G and XM-L's which are not the highest bins). This drop-in is only 1 amp and for that amount of power it was doing really well.
Here are a couple of pictures. These are take with a 2-second exposure to get something as bright as the lights really look. The light is pointed to the fence posts that are about 120 feet away. The white balance is fixed to daylight so you can see tint differences. First here is the XT-E. You really can't see the yellow here since there are a lot of colors. Also I found that the yellow spot wasn't as bad when I took the drop-in out and put it in another host. Maybe I screwed down the reflector while doing that. You can still kind of see some greenish around the hotspot.
Now here is a XR-E R2 which throws really well:
I don't have a cool white XP-G drop-in anymore. So I will have to use a neutral R4 5B that I have, but the reflector isn't matched up for the best throw.
Here is my new Nichia 219. I didn't believe the 92 CRI number, but after looking at this picture and seeing how well the brown foreground and green grass show up, I'm thinking maybe yeah (mouseover for the XT-E):
I got sort of similar results with a neutral Cree XM-L T4 with a 5A3 tint:
Here's the Ultrafire 3-mode XM-L drop-in, which is cool white:
they are very good and very informative beamshots.
From the shots I actually prefer the XT-E to the XP-G or XR-E (save for the latter's throwiness)...but wow, I see a 219 in my future! Love the high CRI. The XM-L 5A3 tint also impresses.
In the meantime I have grown to like my XT-E. The beam is very useable outside, even though it's fugly on a white wall.
Great beamshots brted. I definitely need a better camera
I very much agree with you, especially when SMO reflector is used.
But tintwise:
There is variance in my dropin also. Spot center looks bluish, spot quite good, then little bit greenish etc.
If you happen to have a light / medium diffuser, I suggest to give it a try, just to see "the tints mixed".
I tell you, this has good tint. It is not cold / bluish as R5 coolwhite but it closer to it than 3C XM-L, in which I already start to see pretty much yellow tones.
I used so called 5-layer film and compared all against white wall. XT-E and XP-G on High and XM-L on Med or High.
i love that 219 and also t4 5a3 (which i have)
i'd like to try xtes in a fixed lamp though
