CRX BIG BRASS NUTZ Triple Luxeon v2 5000K - MTN FET Driver - 18650 - Fw Clicky Sw - 3200lm.Hand made
Copper & brass construction, triple layered
Triple Luxeon v2 5000K emitters
Noctigon copper DTP MCPCB
22mm x 2mm ARC glass
Carclo 10511 TIR optic
Green GITD glow gasket
Copper pill
MTN FET Driver (GuppyDrv1)
Copper lined & sprung battery tube
Copper switch enclosure
15A Forward clicky tail switch (djozz test)
Rubber switch boot with copper button cover
Glass covered 10mm x 2.5mm green tritium vial
Green GITD hex switch surround
Max - 3200lm
cd - 6800 - 165m throw
Length - 109mm
Width - 30mm/ 34mm
Weight - 400g (With 18650 cell)Made from some 3/4" brass threaded tube, 30mm brass couplers, brass sheet, 28mm and 21mm copper tube.
This light is a bit of a monster, my heaviest build yet weighing in at four hundred grams.CRX Big Brass Nutz runtime graph: (Still need to do the 40% test)
