Am I the only one to like and use the double-click from off to ceiling (lot of light without (over-)heating too quickly) ?
I have nothing against double-click from off to turbo (as requested by others) but only as an option, or as a default setting if this is reversible to double-click from off to ceiling. Please !
In my understanding the ramp is the usable range and there should be shortcuts for lowest and highest levels in that ramp. Turbo should always be a separate level/mode/action.
Yes, it canā¦ but config canāt be changed while in simple mode. So hereās how to change it:
10H: Go to advanced mode.
1C: Turn the light on.
3C: Change to stepped mode.
1C: Turn the light off.
10C: Go back to simple mode.
Then simple mode uses steps instead of smooth ramping.
Nope, youāre not the only one. I also prefer āOff 2Cā for ceiling instead of turbo. Especially on hot rod lights like the D4, I really donāt want full power most of the timeā¦ I just want a shortcut to a high mode.
Thatās kind of the whole point of having a ceiling level which isnāt the same as turbo. If every shortcut goes to turbo instead of the ceiling, why bother having a ceiling at all?
So Iām kind of inclined to follow SammysHPās suggestion and make it so that āRamp 2Cā also goes to the ceiling. If the user wants full power, they can set the ceiling to full power.
However, a shortcut to turbo would be good too, even if it wasnāt configured with a high ceiling. So Iām thinking about making it so āOff 2Hā does momentary turbo with no thermal regulation. Advanced mode only though; no turbo in simple mode unless the user configures it that way. So in simple mode, āOff 2Hā would be momentary ceiling.
Itās a good question, whether to include lockout in simple mode. I truly donāt know if itās too complex to be allowed in simple mode or not. Some big-brand lights include lockout, some donāt. So I think there are good points to be made either way.
As for what the button mapping is thoughā¦ I really donāt want to make it any less convenient than it already is, because lockout gets used quite a bit. Was mostly trying to decide whether to make it easier to access, not whether to make it harder.
After using 3C lockout for a couple weeks though, I think 4C is probably a better default. Shortening it to 3C seems to have more downsides than benefits.
The distinction between ceiling and turbo is definitely a thing which comes up often, and it would be good to find a way to make it work for everyone. None of the options seem like a clear winner though; there are tradeoffs. So it becomes a question of which tradeoffs to useā¦
Here are a few options:
Off 2C = ceiling, On 2C = turbo. This is the current solution.
Benefits: It needs only two clicks, gives a nice shortcut to ceiling from off, and gives easy access to turbo while on.
Downsides: No shortcut to ceiling while on, no shortcut to turbo while off, and 2C does different things in different modes.
Mitigation: User can set ceiling to turbo, if they care more about turbo than having a separate ceiling level.
Mitigation: Could map āOff 2Hā to momentary turbo (instead of momentary ceiling like it is now). It wouldnāt have thermal regulation during momentary turbo, but some might consider that a bonus.
2C = ceiling, 3C = turbo.
Benefits: Gives consistent access to ceiling and turbo, regardless of mode.
Downsides: Turbo shortcut is relatively slow. Must move battcheck and ramp style toggle somewhere else. Requires either delayed turbo from off, or a bright flash on the way to lockout/battcheck/etc.
Mitigation: None.
2C = ceiling, no turbo.
Benefits: Easy access to ceiling level.
Drawbacks: No turbo shortcut without changing ramp config. Canāt have turbo and a separate ceiling.
Mitigation: User can set ceiling to full power.
Mitigation: Could map āOff 2Hā to momentary turbo.
2C = turbo, no ceiling except via ramp-up.
Benefits: Easy access to turbo.
Drawbacks: Ceiling level becomes less useful.
Mitigation: None.
2C = ceiling if mem less than ceiling, or turbo if mem >= ceiling.
Benefits: Allows both, without sacrificing other button mappings. Avoids turbo unless the user ramped up to ceiling the slow way first.
Drawbacks: No quick, consistent shortcut to turbo.
2C = ceiling first, then turbo if repeated, then back to mem.
Benefits: Quick access to ceiling. Same behavior from off or on.
Drawbacks: Awkward. Must cycle through turbo to return from ceiling. No direct shortcut to turbo.
Mitigation: None.
Personally, instead of making turbo easier to access, I usually want easier access to the ceiling level. Iāve even flashed custom firmware on some of my lights to remove turboā¦ like using the āno FETā KR4 firmware even though my KR4 has a FET and LEDs capable of handling full power.
So Iām kind of leaning toward something like this:
Off 2C : ceiling
Off 2H : momentary turbo
Ramp 2C : ceiling if mem < ceiling, or turbo if mem >= ceiling
This prioritizes the userās ceiling configuration, so they can decide what the maximum should beā¦ but also provides a way to bypass that temporarily for direct turbo from off.
On lights with thermally-sustainable power levels like the LT1, none of this is even relevant. It uses full power by default. Itās only on higher-power lights where this matters. The ceiling gives users a choice for whether their hot rod should behave like a hot rod or like a normal light.
Iād generally recommend setting one ramp to full power, while the other is limited to a sane levelā¦ so itāll be easy to switch between.
The problem with this solution is that we always end up getting into voltage check (triple click) when trying to access turbo which is real annoying especially under tactical situations where we need turbo access immediately.
This is the ideal and is what most UIs from premium brands like Thrunite, Olight, Acebeam, Nitecore etc. use. Itās the most intuitive and the majority of users like the ability for easy direct access to turbo.
As a compromise, I think this is acceptable. We still have direct access to turbo though it wonāt be consistent with the industry standard double click to turbo.
I prefer this method too. Most times I only need ceiling brightness, and when I do use Turbo itās only for a few seconds then my light is too hot to hold.
This also allows the user to set the ceiling to Turbo level if they want āOff 2Cā to go to Turbo.
I think Iām having a different problem. Iāve been using my Supfire M6 lately. Itās got four 30Qs and 3 XHP50.2s on a FET+1+15. Itāll run on full AMCs for a long time before it steps down slightly to a thermally stable level. So I initially set ceiling to max 7135s. The problem then becomes, I get a jump from about 6A to (guessing here) something north of 30 Amps (possibly much higher, but I canāt test). While the double-click to ceiling is nice and how I like things, I sometimes really want to ramp partially into the FET range but canāt. I have pretty nice control of everything from below 1 lumen to maybe 3000? And then a jump to 10K or something. So I can change the ceiling higher, but then my double-click from off goes much higher than Iād like.
I thought about it, and I donāt really think this is something Anduril should, or can in a practical way, fix. Itās also probably only really necessary on the crazy lights, beyond D4 power levels. If I get to the point where it bothers me enough on this light, Iāll just have to write in a change, and manually define 2C from off to always be a certain level, and let ceiling be whatever I want for ramping.
For the rest of my lights, I set ceiling to turbo.
Also, for āRamp 2C : ceiling if mem < ceiling, or turbo if mem >= ceilingā, how could memory be higher than ceiling?
On lights like the M6 or D18, what Iād suggest is setting two different ceilings. Then you can pick one relatively quickly by choosing a ramp and then jumping to the ceiling. This is part of why Iāve kept the āchange ramp styleā function on a short button sequence. I mostly use it to select from two floors, but two ceilings works too.
Specifically, it might make sense to configure the stepped ramp so the highest regulated level is, perhaps, step 6 of 7. Or maybe even step 5 of 7. Or 6 of 8. Or whatever. The steps.py tool is helpful for doing stuff like this. Iād also configure the smooth ramp so it stops at the highest regulated level. Or maybe all the way up to turbo.
Greater than or equal to. So, if the user ramps up all the way and then double-clicks, it would go to full-power turbo. The greater-than part is mostly just a way to cover any obscure corner cases and prevent potential bugs.
Like, if the two ramps have different ceilingsā¦ the user could go up to the higher ceiling, then change ramp styles, and memory could theoretically be set higher than the ceiling. In practice, thatās not how it works since Anduril checks and changes the memorized level while changing ramp styleā¦ but it doesnāt hurt to handle the corner case even if it should never happen.
A lot of programming is about handling conditions which should theoretically never happen.
Iād argue that if you are looking for a light for ātacticalā use, an Anduril light probably isnāt the optimal choice in the first place. There are already plenty of tactical lights with very simple UIs available for this use case.
I really like the idea of 2C always going to top of ramp, from both off or on. This is usually set to a much more usable level than a full FET turbo that can only be sustained for a few seconds. Iād use 2C from on much more often if it went to the top of the ramp since I rarely use full turbo on pocket rockets like the FWxx. If a user intends to use full turbo all the time, the top of the ramp can be easily set to turbo. 2H from off for turbo is a good compromise to keep it accessible if you need to go full blast for a few seconds for ātacticalā reasons.
I finally received my EDC18 two days ago and have played with it since. And it met my expectations and even more, when configured the way I want it I believe it is the best UI on any of my flashlights.
As for Anduril 2 I see the need for the simple UI. I let my wife try it and she struggled with all the clicks, in particular separating 4 and 5 clicks. So when trying to activate ālockoutā she often went into momentary instead, and she had to try several times to get out of lockout. I tried to teach her my way of doing it which is counting 2Cās like One-Two-One-Two for 4C and One-Two-One-Two-One for 5C, but that did not work for her.
The way I see it āLockoutā is a safety feature which most people probably would like to enable on a light, while Battcheck is more of a specialist requirement. I realise you would loose the new features of choosing where to start from lockout (4H floor and 5C ceiling) with 3C for lockout, but I believe it would be much easier for ānormalā users to go in and out of lockout with 3C. I realise that one UI canāt be perfect for everyone, and each has personal preferences, but I would like to know why you concluded that 4C would be better than 3C for lockout after having tried it a bit? Could you elaborate a little on this?
And do you do wishes?
I would really really really like to have the ability to enable the 2H to momentary turbo in Simple UI without raising the ceiling. Is there any way you can make this an enable/disable (with default disabled) feature? One of the really good things about Anduril is that it gives me direct access to 3 adjustable levels from off (floor, manual memory and ceiling), and to turbo when on. Normally I never use turbo for longer periods at a time, so the 2H from off seems like a really nice addition to get access to all four levels from off. I also believe that a lot of other āadvanced usersā would like to set up Simple UI in the way they like it by going through the advanced UI first, but then use simple UI as their default one. And I would hate to have to give up ceiling to achieve this.
Anyway, thank you very much for your dedication and hard work
I would prefer not to have the version check in simple mode. It is not an essential function and it could cause confusion if activated accidentally. Anyone who knows enough to want it can go into advanced mode to get to it.
Agreed. Even though I just read about simple mode, I simply forgot about it.
Or maybe activated by default for something like 10 mins but then to disable it or make any changes then that would have to be done through the advanced UI
The DĆŗnadan
Chieftain of the DĆŗnedain
Heir of Isildur
Heir of Elendil
King of all the DĆŗnedain
King of the West
Lord of the DĆŗnedain
Envinyatar - āthe Renewerā
King of Gondor
King of Arnor
High King of Gondor and Arnor
Lord of the House of Telcontar
It has a sunset timer. Turn the light on, then click 5 times and hold the final press. The light then blinks once per second. Each blink adds 5 minutes to the timer. Let go when enough time has been added.
Then it slowly dims and eventually shuts itself off.
This setting doesnāt stick though. The timer is only active until the light shuts off.
