Thanks Fin17!! Ordered
Convoy Grey XML2 1067lm 2 Group 3/5 Modes 18650 $ 9.99 Flash deals
can you check ?
Flash sale ends
Hello Fin, Could I get a coupon for the Amutorch E3S 3xSST20 please. Thanks
Hi, I would like the AMUTORCH E3S code as well. Thanks
Thank you very much Fin, ordered one
Hello Fin, Could I get a coupon for the Amutorch E3S, please. Thanks!.
Thank you very much Fin.
can i also get the code for AMUTORCH E3S please?
Would the same be possible please?
I wonder how the Wuben LT35-Pro differs from the Wuben L60/LT35 (I’ve tried the L60 and LT35, and they look exactly the same, and basically are the same performance, with only 1 UI change that I noticed: LT35 has 4 brightness levels + SOS, which is part of the regular brightness cycle, and will be memorized), whereas the L60 has SOS mode accessed via double-press, and doesn’t appear to be a memorized mode.
The LT35-Pro’s head design looks different, but the specs still look quite similar to the L60/LT35… I wonder if the zooming distance (widest & most focused) has changed or not (the L60 and LT35 have exactly same focus from widest to narrowest).
Can i also get the code for AMUTORCH E3S please?
Thanks ,last minute order.
thank you fin!
AMUTORCH E3S code please. Thank you.
