That is so neat.
thatâs some great âsheetmetalâ work with the plastic for the control box, very professional looking like it was store-bought. Canât wait to see the final assembly and beamers.
Thanks guys
hey CNCman, hope yall survived the hurricane without any flood damage.
Did you happen to measure the dome height of the lidâor maybe the âsagâ depth of the center with respect to the edge? From that we could calculate the approximate focal length of the âmirrorâ and where to put the light source to make a big flood light.
kennybobby
No problem with Laura here, we are near Bay St Louis MS.
Here are the dimensions for the 12â Pot Lid. I have been adjusting the head position between 7.5 to 8.5 inches ( focal length ). Ordered a medium size reflector to chop up for keeping the light inside the mirror. Right now the weather has been raining , so I hope to get some pics tonight.
This was an attempt to make a throwing light that failed. If it had a true spotlight mirror it would have a chance of success. I will get that mirror when it is in the flashlight budget.
The person who never made a mistake never made anything
I have an app on my phone called âparabolic reflectorâ it calculates your focal length at 170mm. Out of 3 of the same lids I tried only 1 actually focused and even then it wasnt that great. But it just goes to show how accurate they have to be to focus. Would it be worth it to make one out of a space blanket?
This has pushed me to finish a 9 1/4â along similar lines to this build.
Also would it be better to cut the bottom of the reflector you can work out the angle of light you need to hit you mirror and cut it to that length?
Thanks for the drawing, thatâs about what i was guessing (12â diameter with 1â dome)
re: paint
Does the looking glass paint only leave a shiny surface on the âbottomâ of the paint layer?
Would a shiny gloss silver paint leave a good âtopâ surface on glass, or is that asking too much from a paint?
re: focus
Would a plano convex lens be useful to concentrate the output light beam at the focal point of the lid mirror?
Yes, or I hope to do that with the one on order, it will get her in a few weeks.
And Iâm not familiar with the blanket idea.
The âLooking glass paintâ will leave an almost mirror finish that can be seen from the opposite side painted only. The painted side is not the mirror side. The painted side will need to be protected from scratches.
I tried several Chrome color paints and they were terrible, not close to a mirror.
I have a few lenses including a plano convex for experimentation, but all the wrong size, and that is a good idea that would definitely help focus it.
The biggest problem is the mirror, its shape is more unforgiving than I expected. Minor imperfection will deflect light in crazy directions.
Here is the rest of the build with beam shots.
We will pickup with the copper head re-build for 4 x XHP70.2 leds.
Cutting up the first head.
New peices ready to solder.
Finished soldering.
Removing leds from 4 x mcpcbâs on the cheap.
Reflowed, I had to do this 2 times because 2 leds were slightly out of position and probably have failed.
The previous reflector was shortened to fit the bigger diameter head and added a polished stainless steel extension to keep the light out of my view.
Finished copper head
Beam shots, laughing is OK
And that is all for now. Another reflector is on order that will help some, but the real fix is a real mirror.
Thanks for watching and any suggestions are welcome and jokes too
That is some seriously clever well executed work mate. Well done.
I like it, cant wait to see a mirror upgrade.
i guess a mirror is a really difficult to make, but you did great on everything that you made, and it all works and sends a flood of light.
Mirror finish car window tint filmâdo they still make that stuff? i saw a car with some sort of chrome wrap, it was very bright and reflective (too shiny for a car).
i found a 12â glass lid at thrift store for $2 so iâm looking into options for surface coat.
maybe you could lap them glass lids
Awesome! This is a big recoil LED setup that reminds me of my old Ultrafire UF-007/UF-009 which i find quite intriguing! Thanks for building and sharing!
Thanks for sharing this ingenious build!
Thanks everyone, I will do an update later ( 5 weeks ) after the reflector arrives.
Haha you will not be sorry you spent the money they make the ultimate light.
