Just a quick warning: “Bulb grease” is not conductive. It is an insulator used to protect electrical contacts from water/corrosion and arcing. The electric connection is made by the contact points between the two objects.
Sadly this misinformation (that bulb grease is conductive and that conductive substances should be used in flashlights) is shared by hank repeatedly in this forum.
Using any kind of conductive substance in your flashlight will cause shorts and other issues at some point.
good to know, thank you for the heads up. I always use bulb grease when changing my car’s headlights. Always assumed it was to keep rain water out, not help with conductivity.
Correct, that’s the main purpose for it. But in some way it also helps with conductivity because it seals all metal surfaces from moisture and air. This prevents corrosion which would cause contact issues.
Depending on the ingredients, bulb grease might be suitable for flashlights. If you want to be on the safe side, use silicone based grease (the cheap stuff works, but you can also buy the expensive Nyogel that has slightly better lubrication and stability properties).
PS: Edited my previous post to make clear which misinformation I meant.
Just for the record, I thought we’d agreed to disagree about the existence of conductive grease,.
But since you repost the same claim, I’ll repost the response. Google finds a variety of products.
Nyogel is the one that has been recommended for flashlight users for years now. Not all of their products, only the conductive type.
and
Of course you don’t want to gorp it on and cause a short circuit, as cautioned above.
Rather, you wipe the threads to clean them (aluminum oxidizes to make that black insulating dirt you see in the threads after a while, that’s what you’re cleaning up)
Let’s not keep repeating this, huh?
“It doesn’t exist and you shouldn’t use it”
“It exists and here’s the reference”
repeating this exchange back and forth isn’t helpful. I”ll just link back to this next go-round rather than retype the references again.
I don’t think we have agreed, at least I didn’t. I accept that you insist on your standpoint, but I see it as necessary to correct your dangerous advice when I see it.
I’ve never seen Nyogel 756G or 758G recommended for flashlights. The usual recommendation is 760G:
I’ve never denied the existence of conductive grease. But it is not relevant for our use cases. And this repetition is helpful because it might protect other people from ruining their flashlights.
I do have a question about the property of grease used in the threads. As I understand it, anodized aluminum is non-conductive. Electrical current and e-switch signals should be happening within the body via the tube, right? If so, why would I need a conductive grease on the anodized threads of its not meant to conduct any current? Wouldn’t plain lubrication and chemical stability be the priority?
Don’t use conductive lubricant in a flashlight. It’s a quick way to get shorts and leaks which are very difficult to get rid of, and can cause the light to stop functioning correctly.
The type of lubricant needed is dielectric / non-conductive.
It can also be important to make sure the lubricant does not cause the O-rings to dissolve. I forget which types do that, but two safe common types are Nyogel 760G and Super Lube PTFE. Both are dielectric and safe for O-rings. The latter is even food-grade; it’s basically Teflon gel.
Thank you all for trying to help
I connected the head to the battery, the way you described it, I got some sparks initially, smelled some smoke but nothing else. Light is not turning on and no blinks.Then I put on the outer tube, and nothing at all.
retaining rings seem to be tight enough, I didn’t take apart the head yet, I think I need a little different pliers. Dont want to damage the threads
Applying power to the head might cause a super tiny spark if your looking real close, but definitely not a big spark or cause smoke visually or by smell. It sounds like you have a bad driver.
One possible scenario is the person you lent it to might have put the battery in backwards and it damaged the driver. Maybe? IDK. I believe I’ve seen replacement drivers being sold. You’d need to be able to solder the 2 wires going to the LED’s, to swap it. Not too complicated.
One thing to try and loosen the driver retaining ring is to push on one notch with a tool like a tiny flat head screwdriver. Alternate sides. Most snap ring pliers are too big to reach in and grab it.
I don’t know. I see one diode on the MCU power input. I guess that protects the MCU.
I tried digging around and can not find out for sure if has reverse polarity protection. Maybe someone who knows will comment. I am just trying to think of what could possibly happen that might cause the driver to stop working. They are pretty robust.
Another possible scenario might be the other person left it on turbo for too long and damaged one of the LEDs. A shorted led might try to pass current causing a spark when power is connected and a burning smell. Actually, anything that is shorted will do that. Ceramic capacitors used for filtering AC current do occasionally short. That is seen in Apple laptops all the time. In this FW3A driver I see at least three filtering caps. The FET or a 7135 chip could have also shorted, but that’s rare.
You should be able to check whether or not the LEDs are working by installing a battery in the light, removing the lens and using a jumper wire from the black negative connector on the mcpcb directly to a ground point in the head. When a battery is installed you have power going to the LED red wire all the time and the driver basically controls the current going to ground. So if you short it, you will get Turbo power to the leds. You just want to touch the wire super fast to see if the leds light up or not. You don’t want them to overheat.
Here is a basic diagram of a FET driver flashlight. You see how the black wire goes from the mcpcb to the driver? If you short that negative to ground you basically bypass the driver and the LEDs should come on full power. If you short the wire and the LEDs don’t come on, make sure you’re getting voltage on the red wire. If you put 3 to 4 volts across those LED wires it should work unless there is a problem with a burnt-out LED or a shorted out LED.
OK, I’ll defer to TK’s advice hereafter. It’s the conservative approach, no question about that.
I suppose an overheated lamp could vaporize the gel and redeposit it in bad places, on a high powered light.
Tho’ from experience, I’ve got a handful of Arc AAAs on which I’ve long ago cleaned up contact surfaces with [a tiny dab of] Nyogel and cured flickering due to dirty threads.
Note the black powder that accumulates on aluminum threads — it’s aluminum oxide, an insulator, that forms and is scraped off any time the threads are worked.
That’s what you want to remove. Wipe with a clean cloth if you don’t have the recommended lubricant to pick the stuff up.
Aluminum itelf reacts extremely fast with oxygen in the air, so produces a fresh oxide layer immediately when the thread contact moves.
I have an FW3A that turns off around mid-high while ramping up. The problem is intermittent. I can fix it by unscrewing the head and screwing it on again. My thought is a dry solder joint cutting off an FET channel, rather than a contact issue. What do you think?
Try loosening the tailcap retaining ring slightly.
I found that on one of my FW3As I got a bad connection if I fully tightened the tailcap retaining ring. I think the ring caused the board with the switch to not sit quite flat and not get a good connection with the inner tube.
Yes; I did that for a bit, when I was having connection problems, and found it helped. At some point, I jammed the retaining ring in the tailcap and can’t budge it now. This switching off when ramping up is a different matter. I am wondering if it may cut off when the battery falls below a certain voltage; it worked fine last night between 4.0 and 4.1.
Mine at first did the same thing when ramping up. Tightening the tail cap and head always stopped it although I could not perceive them turning. Sounds like the inner tube is very touchy. For whatever reason mine has not done it in awhile.
