Updated with 4000K from Sofirn. Curious how the tint shift vs current is more along the CCT lines whereas with 5000K it’s along the BBL.
Wow. Amazing dataset! Awesome work and thank you so much!!
The reduced angular tint shift is the best outcome of slicing imo - for high CRI emitters at least.
I wonder how much surface finish of the silicone matters? I’ve noticed differences in the past after polishing sliced domes with wet stones, but can’t quantify anything
My Wurkkos FC11 LH351D 5000k 90CRI had an atrocious green tint. I sliced and sanded the dome, but I did not take all that much off as I only had a thicker washer at the time (probably around your 1.5mm range IIRC.) Results per my eyeballs as I have no other way to test: a bit warmer, a TINY bit less green, and a bit tighter spot. I was expecting more of a difference in DUV, your measurements support my eyeball “data” in this particular example. Thank you for this information, I may try to track down a thinner washer for a deeper slice. However, I also added a Zircon filter, so may not need it. Still not quite the tint I want, but passable.
The FC11 LED is honestly the worst LH351D i’ve seen so don’t feel bad and in fact it will be worse than these measurements in the stock reflector because the above tests were with a beaded TIR.
Here is my stock FC11 and then sliced on high measure:
I’ve tried to polish after slicing before, but It didn’t seem to polish anything, felt like triyng to polish rubber or something, maybe I didn’t use the right grit size stone.
A good razor blade seems to make a very clean surface though.
Mine was arround 0.0085 on turbo at turn on, that’s the same LED on the graph, so yes the spot has a lower duv with the beaded TIR.
edit : I notice I forgot to put 0.85mm on the second graph so I added it.
Updated the first graph with 2700K sliced to 0.85mm to show how warm it can get.
Added 5700K V2Q1S2 from Convoy.
Very useful info!! Thanks so much for compiling all the data for us! Seems like shaving reduces output the same as using minus green filter and achieves the same lowering of DUV. Only difference I guess is shaving results in a more uniform beam and improves throw.
I have a sliced 2700k in a Tool AA. After slicing the emitter, I gained some strange artifacts in the hotspot, but after some sanding they disappeared. I’m not sure if this was because I didn’t do a great job on the initial slice, or because this light has a smooth reflector. I have another sliced Sammy in an OP reflector and it looked great without any sanding.
Thanks.
Yeah basically.
I don’t have this flashlight but I think I’ve heard the reflector has some issues like this with some LEDs.
I sliced a dogfart and I like it.
5000k LH351D, the good bin. I used a spacer(3 layers of thin card) to get an even cut. Had to cut from two sides to get even. Installed in a C8 with a blf a6 driver and an OP reflector.
Now one of my favourite lights. Decent throw intensity, usable spill. Even beam with no artefacts. Definitely warmer than 5kk. Seems great CRI I assume the slice doesn’t reduce CRI.
A great allrounder outdoor light.
Any chance you’ll be testing a 3500K variant? Curious about that CCTs tint shift vs current… I prefer the behavior of the 5000/5700K as Duv doesn’t change much with current. 4000k is almost perpendicular to BBL. I’m guessing 3500 is similar, but there’s only one way to know.
Thanks again. This is awesome and priceless data.
Yes, I’m going to order some stuff on digikey and I will take some 3500K.
Anything else I should order at the same time ?
Edit : Contactcr tested 3500K , it has the same behaviour as 4000K with current.
I’d be interest in how the SST20 4000k and 2700k behave in this regard as well. Also, you won’t be getting any from digikey, but I used to shave 219Bs back in the day b/c I found them too cool. They really warmed up a lot and got very peachy/rosy warm. Very beautiful but they just didn’t make enough light.
Even CW emitters like SST20/40 and XHP 50.2 would be useful data points, but mostly biased towards throw and maybe angular tint shift.
Oh and thanks for the link to contactr’s tests!
So I already tried to slice a SST-20 2700K and a XHP50.2 cool white from a Thrunite (unknow CCT)
For the SST-20 the duv barely changed, like –0.0003~–0.0005, CCT dropped ~90K, as I am most interested in tint, I didn’t deem this worthy of more testing.
For the XHP50.2 I only measured the bare LED quickly, original :
0° CCT = 8061K (Duv –0.0065)
25° CCT = 7191K (Duv –0.0031)
45° CCT = 5690K (Duv 0.0076)
60° CCT = 4802K (Duv 0.0199)
75° CCT = 4713K (Duv 0.0208)
What an absolute nightmare of an emitter
sliced :
0° CCT = 5227K (Duv 0.0084)
25° CCT = 5101K (Duv 0.0100)
45° CCT = 4964K (Duv 0.0123)
60° CCT = 4791K (Duv 0.0152)
75° CCT = 4531K (Duv 0.0203)
Less tint shift! but the whole thing got greener. ‘throws into the trash’
I have some 219C 5000K 9050 that I could try to slice.
Good work and many numbers. But one simple question - Does this means its time to teardown my SP36 5000K and try to slice to about 1mm?
If I am reading numbers correct, I will get warmer CCT (good), even more throw (good), and a little bit lower duv (good)?
All good except some output losses (–15~–17%).
But the SP36 is not easy to open I read, the driver is glued (needed to be removed to access the MCPCB), I remember seeing somebody soldering solid wires on the driver to pull on it.
Output losses probably will be compensated by slightly better throw?
My SP36 driver is already glue free and flashed with latest Anduril. Will remove reflector and MCPCB if needed.
Yes, 170% intensity, 130% throw distance (square root of 1.7) with the optic used in the test.
I noticed less angular tint shift in my sst20 when sliced. Not too much but noticeable. It lives inside my converted fw1a with a convoy s21a reflector.
