Gonna say yes drivers are different,
Got the WK01 and tried to put the head on a Sofirn PF04, Thorfire PF04 and will not work, head is shorter, threads different depth.
I know people will say “just make a contact ring” but that would not be a good idea as I did put a LifePo 10440 in the WK01 and the modes just do not change and it really did not get much brighter so higher voltage is probably going to kill the driver with no gain, no upside.
Flashlight really works well at the recommended voltage though and the tint is awesome!
Could probably get away with primary lithium AAA which is usually around 1.75-1.80 volts and may see some increase in output.
Do wish it had mode memory, always starts on moon. Sometimes I need it to start on high like in daylight use under car hood etc.
Thanks! This gave me the courage to try an INR10440 at 4.2V in the WK01.
I found it difficult to get it to switch mode from Low to Medium and High while using a 10440. It looked like it was stuck on Medium.
I had to rapidly momentarily press the button forward to change from Low to Medium and High and then click it in. If I tried to slowly click between modes it remained in Low.
The beam looks nice on high with a 10440. It seems slightly brighter than an i3T on High with a 10440.
10440 Low is like AAA Medium
10440 Medium looks 30% brighter than AAA High
10440 High is looks 30% brighter than 10440 Medium
If you run it on High with a regular AAA for a minute, that’s about how hot it gets when running it on High with a 10440 after a few seconds. I wouldn’t recommend using a 10440. Something might burn out…
Ahhh...besten Dank für die Info! Wurkkos sagte 20% Discount, so dass es eigentlich € 12,79 statt € 11,99 sein müssten.
Falls Du Dir die WK02 auch noch kaufen solltest, sag mir mal bitte Bescheid, wie hoch der Endpreis ausfällt. Danke!
I will ask but that's one of those questions only Wurkkos can answer. Would Amazon US be an option for you? I suppose it would add quite some shipping cost, right?
