Yes, this is something I was also aware long ago. In Simon's shop any and all items feature “built in” shipping cost, this means the basic shipping cost is included in the price of the first unit of whatever thing. If this were a very small amount, this could work, but it is not a small amount and so it doesn't works.
The solution is to set the shipping cost independently, so the actual item value is reflected in its price. Allow the shipping cost to add afterwards. Many AliExpress sellers do it this way, and it works. As sellers, you are fully responsible for both the costs of items and the cost of shipping and handling. After all, what the buyer sees is the total to be paid, this is what counts.
That's the thing, shipping is not cheap for minor items and when you order so many different little items together, it just isn't worth it. I always prefer to order from Simon as he is a good guy, always helpful and knowledgeable, but it would be nice if he could make it easier to adjust the shipping.
I’m buying my first true flashlight. The convoy S2+ is the obvious choice.
I’ve been studying, reading and comparing for some time, to decide on SST-40.
This was true, until I recently discovered Simon offers S2+ with LH351D with new 5AMP (non 7185) driver.
I checked specifications along with test here on BLF online - and it seems that 3AMP is maximum with LH351D, unless I want to risk my led to burn.
The question is - how does the 5AMP driver works with LH351D? Doesn’t it destroy the led? Is this driver safe with this led? Or do I need to set the 12group driver to e.g. 0.1% 1% 10% 50% and never put it on 100%?
Yeah, the only thing that I would consider limiting to 3A is Nichia emitters - E21A a lot less, but 219b is about 3A. LH351D, I’d throw 5A at it without blinking.
Last time I selected webmoney as a payment method, it sent me to webmoney website then I closed the page, the order was left ”unpaid” and I could ask Simon for blf discount/consolidate shipping costs
That test is what we have to refer to but I've been using a Convoy 4 mode, 6A driver in an S21A for a while and there's been no issue.
In fact, what I've seen in my SP32A, D80v2 and the S21A with a LH351D is no amp reading higher than 5.5A. So, I think that LED will be fine with a good thermal path.
Personally, I'd go with an SST40 unless the hi CRI is all out necessary.
Has anyone else had an issue with the Omten switches squeaking? I have a fairly new S6 and S2+, and both switches squeak on half presses? Anything I can do to quiet them down?
