Got my XT-E drop-in from KaiDomain today. I love that it has 3 modes using the NANJG AK-47A driver. The drop-in has a smooth reflector, but the beam has a definite yellow center. The edge of the hotspot is a little green or yellow. Not sure if Cree will be able to work this out.
I tried some 3000K warm white XT-E in a homebrew 4x Mag mod that I'm not done with yet. I tried a variety of reflector shapes, sizes and textures and even a few optics. The one and only thing I tried that gave pleasant uniform color (instead of banana-berry swirl) were Ledil Boom Spot 20mm microfaceted reflectors. I'd venture a guess that a Fraen 34mm microfaceted reflector might look good as well, but I don't have any spares or room for them in the light I'm building.
Remember when the XMLs first came out we got horrible color change like that also. Hopefully quality control will come up after a while and we will get more even color dispersion
I got one too and while I was a little disappointed by the beam it produces, I don't think it's all that bad. To me, the beam is somewhat similar the what you would get from an Edison Opto Edixeon LED which like the Seoul Semiconductors P4 and P7 also uses a Cree die (EZ1000?). Anyway, if you're a flashaholic and you don't mind having something different in your collection, still not a bad thing to have an XT-E P60 dropin in my opinion. I find the mix of yellow and bluish-white tint of the beam as a hybrid giving you cool and warm white all in one beam.
I'll try to get some outdoor shots tonight. I took it out last night and the yellow dot is noticeable outside, but I was pretty impressed with the throw of the drop-in. I was comparing it to a couple of other lights and it was doing quite well, but I need to compare it to a cool white XP-G to be fair (I was comparing it to some neutral XP-G and XM-L's which are not the highest bins). This drop-in is only 1 amp and for that amount of power it was doing really well.
Here are a couple of pictures. These are take with a 2-second exposure to get something as bright as the lights really look. The light is pointed to the fence posts that are about 120 feet away. The white balance is fixed to daylight so you can see tint differences. First here is the XT-E. You really can't see the yellow here since there are a lot of colors. Also I found that the yellow spot wasn't as bad when I took the drop-in out and put it in another host. Maybe I screwed down the reflector while doing that. You can still kind of see some greenish around the hotspot.
Now here is a XR-E R2 which throws really well:
I don't have a cool white XP-G drop-in anymore. So I will have to use a neutral R4 5B that I have, but the reflector isn't matched up for the best throw.
Here is my new Nichia 219. I didn't believe the 92 CRI number, but after looking at this picture and seeing how well the brown foreground and green grass show up, I'm thinking maybe yeah (mouseover for the XT-E):
I got sort of similar results with a neutral Cree XM-L T4 with a 5A3 tint:
Here's the Ultrafire 3-mode XM-L drop-in, which is cool white:
From the shots I actually prefer the XT-E to the XP-G or XR-E (save for the latter's throwiness)...but wow, I see a 219 in my future! Love the high CRI. The XM-L 5A3 tint also impresses.
I very much agree with you, especially when SMO reflector is used.
But tintwise:
There is variance in my dropin also. Spot center looks bluish, spot quite good, then little bit greenish etc.
If you happen to have a light / medium diffuser, I suggest to give it a try, just to see "the tints mixed".
I tell you, this has good tint. It is not cold / bluish as R5 coolwhite but it closer to it than 3C XM-L, in which I already start to see pretty much yellow tones.
I used so called 5-layer film and compared all against white wall. XT-E and XP-G on High and XM-L on Med or High.
Sweet shots brted . Didnt see these pics before. I ordered one of the 3 mode drop-ins OP earlier this month but have not received it. These pics make me want it even more!
Received my drop-in Saturday. It has the same color in the center all others have reported. Draws 1a at the tailcap. I would assume that it will run a long time at the current. I actually like the tint of the xt-e outside.
This is my first drop-in that is not an xml or green. I would think the xt-e would work with a smaller host like AA or 14500 type.
Would this led fit in the place of an xp-g in the reflector area?
Informative beam shots by brted, yet not, until we know the drive levels in these shots: If amperage in these beam shots all are equal, the xml is winner. However, a halogen might win if you pump 150 watts into it.
What are the current for each of these?
Runtimes for an ideal light should be 2 hr, 4 hr, 8 hr, 16 hr and 100 hr. 280 milliamps is max real world drive level for a work day work light.</rant?
The XR-E is just a budget drop-in so no telling the driving current, as is the Ultrafire XM-L which some people measure at 4A but is probably really around 3A at the tail. Those are essentially direct driven. The XT-E is a 1.05A 7135 driver. The XP-G and Nichia are at 1.4A 7135-based drivers (though the neutral XP-G above seems dimmer than it should; something may have been wrong with that one), the neutral XM-L was 2.8A with 7135’s. These were all P60 drop-ins and hosts.
