Thanks for your review Mocarny. I really enjoyed it.
M21C-U seems to be a good flashlight except for its ramping UI clumsiness.
Simon mentioned that the upcoming Convoy M3-C (M3 with USB-C charging) will have ramping UI, hopefully it (and the next batch M21C-U) will have a better ramping.
Simon also mentioned about M21C-U will be upgraded with USB-C.
Seems like a good move forward, more Convoy models with e-switch, and USB-C.
Hopefully they’ll also come with a better UI.
Great review indeed.
For new M21C -U I prefer non USB-C variant if we want to have best waterproofnes of it. Also most of times I prefer to charge my batteries with external charger. The problem with most powerful flashlights is that USB rubber cover frequently pop out from internal air pressure when flashlight body is hotter. For example SP36.
Just get my black M21C-U with 3000K.
Step changing mode enable after clicking 6 times from off position. And we have 4 comfortable positions: minimal for low light in room (1), second for walking in the night woods (10), third 30, and fourth - 100. Returning to stepless dimming - 6 times clicking in off position.
For me it’t absolutely best mid-range light.
I hope Simon doesn’t let himself to persuade himself to implement onboard charging into his lights by people who use their lights as toys, where for some people flashlights are tools on which their safety depends on, eg. while caving or doing urban exploration.
Hi, I updated my review, decreased host and build score because of rattling reflector. I discovered it is not only my problem, my friend ordered about 12 flashlights and each of them has the same problem.
If you have this issue too, let me know.
Yes, this is a very common but in no way it is a big issue
This is a step by step :heart_eyes:
1- Open your palm.
2-Hold the flashlight by the head
3-Push the head inside your palm
4 Screw clockwise
5 check rattling and repeat 3,4,5 until you hear no rattling,
you can also do it with a self healing pad or mouse pad….
I have 3 M21C-U. All came with reflector rattling. And all 3 the SS Bezel not tighten. Not sure if this is on purpose by Simon as some will prefer to change an OP into this light like I did.
Not a problem for me with them rattling. Once tighten SS Bezel, rattling gone.
By the way, I have more than 10 Convoy lights, all the Bezel came not tighten. Again, I’m not sure if this is on purpose.
This lantern has a different bezel mount design. The sealing ring does not rest against the reflector, but against the lamp housing around the perimeter. When tightened, the bezel first pushes the rubber band, and only at the end presses the reflector. As other participants in the discussion have already written above, when tightening, you need to press firmly with your palm.
Hope my “lame” english can be understood ).
I figured out how, when turned on, it is guaranteed to get into the first low mode. If you turn it on by pressing 6 times, then the control mode is changed with the inclusion of the minimum mode. The crutch is certainly uncomfortable, but it’s better than getting an unexpected turbo mode.
For some reason, the following began to happen with my flashlight: when switching from a stepped mode to a smooth ramping mode, in the first few seconds the flashlight spontaneously raises its brightness by three small steps, up to about 90lm.
I added 3 more beamshots of stepped ramping mode in the Beamshots section.
And it’s worth mentioning I edited the review after some time and added info about simple 4 mode UI available after 6 clicks. Sorry I didn’t mention it earlier, and I gave this flashlight worse rating than I should. I changed that too.
