[Update]Wurkkos dual LEDs 21700 Headlamp design Photos/UI update~
[quote=Tom E]
The 130g weight spec’d is the the flashlight and head strap together, no battery. I don’t know why they did this, but it’s the only thing that makes sense.
The actual weight of the HD20 with no battery, no clip is 87g, not 130g.
Thank you, we will check and modify the manual
We are testing more and improving the reverse charging function, the first batch, no problem for charge flashlights, huawei phone, MI phone ,ect
Here: On Banggood at $66 US. Even at a good price, it's pricey.
HKJ review here - he likes it!
Not available on Amazon.
Good to hear. We noticed it's showing no stock on the Ali store and Amazon now.
lux-Perpetua should have the full summary of manual changes for the UI, and list of bugs.
Hey Wurkkos. I ordered the HD20 with the battery and it seems to have a flashing red during a 90 minute charge. The charge indicator never turned green. Via the manual it says the battery is critical so I tried swapping it out with another battery and the problem was not resolved. I ordered the light off AliExpress on 11.11.20. Any advice on this issue would be appreciated. Thanks.
During charging the indicator blinks red and switches to constant green when finished. Charging can take up to three or four hours.
My FC11 is a solid red when charging. I looked around and found info regarding the below. I don’t think my battery would still be below 3% after a hour charge. Also the other batteries tested were running well in other flashlights.
3% > Flashing Red
30% > Constant Red > 3%
Constant Green > 30%
Per this manual: https://drive.google.com/drive/folders/1MibSgwWIBUqBfb6VgZSPhusiyT7ZE_yH
Per these reviews:
[Review] Wurkkos HD20 aka Sofirn HD20 (dual light, 21700, Type-C, magnet, HiCRI, 5000K)
【ツ】Wurkkos HD20 Sales Thread - updated revision and available in green color
That’s the indicator when not charging. While charging it blinks red. Plug it in and wait four hours.
Ok. Thanks. Will give this a try.
We Tested discharge of HD20 again (batch 1#) different phone and products shows different discharge current, so different equipment will influence the reverse charging current.
Charging by 18W Adapter
HD20 Reverse charge the other HD20 1.67A
HD20 Reverse charge FC11 0.92A
HD20 Revere charge Phone#1 1.08A
HD20 Revere charge Phone#2 0.93A*
HD20 Revere charge Phone#3 0.46A
Iphone can not be charged by batch#1, reverse charging current will update more stable from 1A-1.8A, and will compatible with Iphone for batch #2
Output voltage is to low. To charge phones at full power you need to keep about 5.2-5.3V .
The meter is placed at the end of the charging cable, I think 4.85-95V is fine.
Sure, if you like slow charge :smiley:
Workkos, thank you for improving this unique light.
Is it possible to offer more LED options when this light is re-released? I believe several suggestions were made earlier in this thread.
SST-20 4000k 95CRI for the throw LED PLEASE, would take this light to another level IMO, and Sofirn already uses them and should have stock.
I’ve just ordererd a HD20 on aliexpress.
A question : is the firmware upgradable ?
A remark : for the turbo i would like the annouced first, ie both flood + throw instead of only the led used befor going TURBO. I will use it on flood for the main part and may need turbo on throw while lost in the wilderness.
Bonjour yann et bienvenue au BLF!
It is unfortunately nearly impossible to flash/upgrade the internal firmware. Maybe a few people who know how to get access to the MCU and its pin address translation will be able to modify HD20's firmware. But there is no interface available from the outside.
Please check >>> here <<< to find the updated manual which reflects the actual UI implemented in the first batch of HD20.
Veuillez me faire savoir si vous avez des questions.
Now HD20 Green version is available on www.wurkkos.com, check it out.
Are there any coupon codes for this?
