id30209
(id30209)
October 15, 2020, 1:55pm
127
Unheard:
Naiv question: The R50 pro only uses 6V XHP70, correct? I imagine a domeless LED would give it the missing throw. Don’t own the pro since it’s inferior in this regard, but if there was a nicely tinted, throwy LED, I’d be tempted.
GT-FC40 is 12V and if R50 is running on 12V then you could swap emitters without problems.
But if it's 6V then you won't light it up with FC40.
Unless you are talking about shaving the dome on the present LED installed in R50, then yes, you will get more throw
A4 bin 2x, A5 bin 1x.
In the event the A5 bin won’t become available for a long while, then A4 bin 3x.
id30209
(id30209)
December 1, 2020, 8:41pm
129
Thanks to zak.wilson i have made another great host even better.
Thrunite T2 is now highly desirable item
I just realised i’m running out of FC’s O_O
thefreeman
(thefreeman)
December 1, 2020, 8:46pm
130
Looks great.
I just want to mention that the glass lens on my T1 added arround 0.0020 duv, have you tried without the lens to see if there was any difference ?
id30209
(id30209)
December 1, 2020, 8:49pm
131
Mine is coated with Joshk miracle paint called “green delete” :)
id30209
(id30209)
December 1, 2020, 9:09pm
132
Aaaand with this build i actually used all of them.
So...payment sent for 3ea, tracked shipping.
Thx!
djozz
(djozz)
December 1, 2020, 9:27pm
133
How can the Thrunite T2 modded with this led? Is the XHP70 from the stock light circuited for 12V?
Edit: never mind, found the answer in another conversation: yes it is used at 12V configuration
I just discovered it’s 12V today after my second attempt at getting the bezel off. My thoughts went immediately to this emitter, and I just paid for three of them.
thefreeman
(thefreeman)
December 1, 2020, 9:35pm
135
Ah ok then, but if the lens is doing +0.0020 then paint say –0.0020 then it’s like using a good lens but with light losses along the way.
id30209
(id30209)
December 1, 2020, 9:46pm
136
I haven’t noticed output drop with this paint as Joshk also confirmed. Maybe after 2-3 or more coatings but not with thin 1 layer i have. It’s not like Lee filters...
lukehale
(lukehale)
December 2, 2020, 5:44am
137
I JUST ordered a T2 and GT-FC40s to do this exact same mod. AND I plan on using my Green Delete too. How did you manage to get yours apart? And how is the output relative to stock?
I’m very excited to get mine done!
0oklight
(0oklight)
December 2, 2020, 8:38am
138
I am very inspired by this T2 mod too, having had three of the LED’s lying around for a couple of months.
Does anyone know if the 12v driver in the T1 will drive this LED at less output in comparison with the driver in the T2?
One 4000K please, if still available
thefreeman
(thefreeman)
December 2, 2020, 9:28am
140
0oklight:
If I remember correctly it is 1A. I don’t know exactly about the T2, but zeroair measured 4000 vs 1600lm, so it’s much higher.
The T1 uses a XHP50.2 though, a 7070 LED wont fit with the stock reflector.
rngwn
(rngwn)
December 2, 2020, 9:51am
141
4000k is up for ordering and there’s quite an amount left. You can pick & choose the shipping method (in the other thread mentioned in the OP) then make payment.
0oklight
(0oklight)
December 2, 2020, 11:11am
142
thefreeman:
0oklight:
Thanks for this info thefreeman. I am right in thinking that you have modded a T1 with this LED? And if so, did you order the correct gasket separately?
thefreeman
(thefreeman)
December 2, 2020, 11:28am
143
No I have modded one with quad E21A but not this 7070 LED.
0oklight
(0oklight)
December 2, 2020, 12:08pm
144
Okay good to know. Will buy a T2 for the mod then.
id30209
(id30209)
December 2, 2020, 4:05pm
145
Oveready V4 with LuxRC engine (triple 219B sw40 by Azhu)
OR is on MAX 21W setting and T2 on HIGH (not Turbo)
Almost the same.
Here is evident why i’m constantly saying it’s 4500K-ish instead of 4000K. :)
contactcr
(contactcr)
December 2, 2020, 4:16pm
146
D80v2 with GT-FC40 4000K and 20mm MTN-BST3 driver, reamed reflector (probably more than necessary)
[image]
High (stock lens)
[image]
High (with diffused lens)
[image]
Definitely ~4500 in hot spot with reflector ^
