Sofirn SC31 PRO, New Anduril Flashlight
Yep, got both and have used them side x side several times. I would not buy the 5k (or 4K version of the IF25a) for outdoor use where I live.
If you have woods out back the lower tints are probably preferred. But here in Kansas I need to see out there a ways… and I personally felt the 5k tint just didn’t get out there like the 6.5k. On turbo both threw nicely, but the 6.5 was clearly the better thrower.
AND, as this light gets SO hot (SO quickly), I set my ramp limit to about 70% on the SC31 Pro 6.5k and I’m happy with it (also using a 50g at 10A/5000mAhs so it doesn’t overheat so fast when I do run turbo- rarely).
The beam tint of the 6.5 is a real winner too- NO blue and little yellow. I nice white beam at closer to maybe 6k (guess). Compared to my SP33V3’s 6.5k color (on the white wall), I can easily see a warmer beam from the SC31 Pro (which matches the IF25a’s beam color too. Both have great tints).
I got the “6500K”, and trust me on this, unless it’s mislabeled, it’s nice. There’s even a yellowish hint in the hotspot, so all the blue must go into the spill, but there’s nothing objectionable in that at all. A little fried-eggy, but not bad at all.
My 5700k SP10B seems bluer than my SC31pros.
Thanks! I think I will get the 6500k sc31pro as my 5000k sc31pro high doesn’t seems as bright or as throwy as even my SP32AV2
Tendou, The SP32A has a slightly deeper reflector while the cooler temp of the SC31 pro 6500K is visible a little further than the 5000K but have the same reflector.
In my signature items, there's a link where I modified an sp32A v.1 with an SST40, 5000K. The driver has higher amp draw than the SP32A v.2 so I really fought and held off for a sale to buy an SC31 pro because I already had a super badbutt EDC. Anduril had a slight influence in my decision to buy the SC31. ;)
Yep… the Anduril UI, and USB C charging is a seller for sure ;). I have to be careful to who I give an SP22aV2 to. It’s a nice UI for someone willing to play with it long enough to learn it, like Anduril.
But the extra maintenance of charging batteries outside of the light has been a challenge for some people (like my mother-in-law, the perfect muggle tester for me). She didn’t touch her SP10 after the battery died. But she can plug her (new) SC31 Pro into her USB charge station NEXT to her phone… no problem.
Nice modification. I’m selling my 5000k and getting the 6500k. Sc31pro stills a good light
Sorry to ask you again. I read your post and understand that for if25a the 4000k really lost much the throw and brightness compared to 6000k version.
But for31pro, how much did you think the throw and brightness differ between the colour temperature when both are on high and both are on turbo?
Thanks again.
You bought the 5000k? How badass it was compared to your sp32av2?
Tendou, not the 5000K SC31. I just modified an older SP32A v1.
I bought a champagne v2 for the wife but I like v1, better.
Ah, I understand. The original sp31v2 without modification already do have greater power than the v2. How do you think the sc31pro 5000k stacks to those sp32av2 and v1?
The frustration with these lights is that they ALL get hot fast. The SC31 Pro 5k is closer to the 6.5k but it doesn’t keep up on throw (as expected). But it does ok on turbo for short bursts (better than I expected).
But again, these are all really cool lights and IF I lived in the thicker woods back east, I’d maybe prefer the 4K IF25a for its super natural tint (as I’d not need the throw). Indoors, the IF25a in 4K would be the favorite. It’s really all about what I am using it for.
For Kansas and seeing across the corn/bean field (several hundred yards) its going to be a 6.5k’ish light every time. If I am checking a trap line (over an hour in the field), I’d maybe take my SP32aV2 (in the 5.5k tint range) for better run time at higher lumens than the SC31 Pro :smiley:
Thank you. I’m sure to get the If25A 6000k this time. And you just make me not wanting to sell my SP32AV2.
It’s also interesting that I saw sp35 21700 are on sale again. With buck driver.
Anyone used unprotected flat top battery with this?
Yes, it comes with one in the kit.
I have sold mine so cannot confirm bit I think it comes with button top batteries.
All my ’pros came with BTs.
In fact, I can’t recall even a single Sofirn cell that was a FT, as all the ones I’m looking at are BTs.
(I always pull any come-with cells from the lights and store ’em separately.)
Seems to be true not just of the all-black 3000s but also the older black-with-silver 2800s as well.
Mine certainly did not, it was an unprotected button-top!
Yeah, you’re right. Just checked and it’s button top. Sorry.
So the question still remains. Anyone used flat top with sc31pro?
Yes. Not a problem at all ... flat top GAs, 30Qs, 35Es, 25Rs...
I have an MJ in mine today.
