Miguel, I tried to contact FF via their contact page. It is not functioning… Wanted to ask same question, how long before the new lights are available?
E12R :
——First 40pcs E12R nichia (Around 20th December) ,6500Lms , CRI98, Highest CRI98 rosy color
—- SST20 6500K / 5000K (Around 25th) , Max 9800 Lumens , Tint is a bit green on Low modes
——XPL2 HD CW 6500K version (Around 25th December) , Note: XPL2 HD is very cool white and tint is a bit bluish on Turbo
—-Sumsung LH351D W2 CRI80 5700K (Around 25th December) , Brightness 1000 Lumens , CRI80
—-Sumsung LH351D CRI90 4000K (Around 25th December) , Brightness 7800 Lumens , CRI90
NOV-MU
—-Nichia E21A SM455 4500K R9080 CRI99 5200Lumens (Around 20th)
—-Nicha E21A Sm2050 2000K R9050 CRI95 (after Xmas) , 3800 Lumens, This emitter has very rosy tint, but emitter supply from Japan has some delay.
I took it as 10,000 lumens, with high quality “Sumsung” LEDs. I am just joking, I certainly can’t speak two languages so what do I know of phonetics and honestly Jack can write English better than I can usually. I am thrilled with the new models and can’t wait to test them all out, I have a few of each model coming since they are a combination of high CRI, awesome bins, and USB-C, an award winning combination in my mind.
From Jack: Firefies pogo programmer key will be available soon, This pogo key is compatible with USBASP, and only supports to reflash drivers on new fireflies flashlights. It supports common USBASP and 10-Pin cable.
Hank has had issues with this as well, and more recently. I have a D4V2 with E21A emitters that can crush almost any size 18650 unprotected cell because he used a brass button in combination with a spring on the positive battery terminal. I am not sure how many were sent out that way, but Hank has tons of experience and sometimes mistakes just happen. At least with Hank or Jack if you have an issue they will either repair it or offer/sell you parts to fix it yourself. Some companies like Astrolux won’t sell you individual parts like drivers or honor any warranty, leaving it up to you to source parts or throw it in the trash, and that is unacceptable. Jack has always helped me buy replacement parts, and his customer service always has been reasonable.
Still waiting for T9R, no news from FF about an upcoming shipment.
I`ve seen in the thread of another FF model, that they are going to start sending them, but without a specific date, and I have not received any mail from FF.
The information I posted above came from an email from them a day earlier. Not sure what hold up is but I’m glad they are testing product to get it right before releasing.
This is the email I got last night, they are shipping the T9R any day now since they have passed testing. The E12R has been delayed another 2 weeks or so but honestly I’m glad they are doing all the testing and making sure when we get the lights they are working properly.
a big factor is surface area. OSRAM is 1 mm2, while, say a 5 mm x 5mm LED is 25 mm2, so 25 times the area. Dunno what the size is of an SBT90.2 off hand, but just as example of 5x5, the LED would have to be 25 times more lumens than the OSRAM to have equal surface brightness.
The SBT-90 is a 9mm² die. Luminus nomenclature is straight forward; They put the emitter surface area (multiplied by 10) right in the name. 10, 16, 20, 40, 70, 90, 140 …most are exact figures. I’m not sure how they handle domed emitters ‘apparent area’ though TBH. The reason I mention this is from what I know, the SST20 is a 1.7mm² die. It might be closer to (likely greater than) 2mm² with the dome’s magnification. That’s the only model that I think deviates from its name in exact mm².
