I always say, the place a flashlight is needed most is “where the sun don’t shine”!
I finally got a proper an image hosting account today. Dropbox doesn’t seem to work for everyone, and hosting them on my server is cluttering the logs.
I almost chose imgur, but they required me to put my personal cell phone number into their database. NOPE. We all know those things get hacked all the time.
So I chose ImgBB.com. It seems nice. It doesn’t have any basic editor features though, like correcting a sideways image.
I went back and updated my posts with ImgBB links, but there are quoted links I can’t edit. Can I get some help guys? Here are the posts and links you need to know to make it a quick job. It would be much appreciated.
raccoon city - post#27 - https://i.ibb.co/vzt4hJ4/hand.jpg
Scallywag - post#31 - https://i.ibb.co/vzt4hJ4/hand.jpg & https://i.ibb.co/sQ9GjWw/button.jpg
pinkpanda3310 - post#34 - https://i.ibb.co/GQz1ppB/sup.jpg
Scallywag - post#35 - https://i.ibb.co/GQz1ppB/sup.jpg
Thanks!
Dund’d
One ping only…
Has the bronze/silver sheet turned up?
It will be a few weeks until it is due to arrive. I took the cheapest steel option they had, they call it “polished bronzed-silver steel”. That’s going to be an interesting material to check out. It’s been years since I ordered anything from Shapeways, and I have never ordered anything but plastics from them before. This is going to be a first for all of us to explore.
If it’s going to be a few weeks there won’t be time .
There are only effectively 12 days left when you take out the holidays and non delivery days, and then you’ve got to make it and write the whole thing up.
I would quickly try to grab a substitute from somewhere or there is a good chance you won’t be able to finish, and that would be a shame.
This was shipped December 24th. Below is a full list if all the tracking events during it’s 1 week transit:
December 24, 2020 - Pre-Shipment Info Sent to USPS, USPS Awaiting Item
December 30, 2020, 6:10 am - Out for Delivery
Fingers crossed it arrives today for you!
Uh, I’ve spent 3 hours trying to make the printer start correctly. It worked perfect all last week. Now it prints 2mm up in the air, and won’t respond to manual adjustment. But otherwise works fine.
As I mentioned in the other thread, this is done, I’ll be posting everything tonight. My family life is very demanding tonight, the posts might come slow.
I did throw together a YouTube video, the link will be posted as soon as the upload is complete.
A quick application of solder paste using the tip of an exacto knife…
Held over a heat gun to reflow…
And bingo.
Then a few wires.
The metal was 4% too small, so I spent about an hour with a Dremel removing material from the inside.
(This is not a one-day build, I fell behind with BLF updates )
After Dremeling about 0.5mm off the diameter of the MCPCB it installed nice.
As you can see the negative wire is both designed to make contact with the metal 3D print for Ground, as well as make the press-fit easier and more secure.
Then I designed and printed a plastic isolator with a bump to press the positive wire against the battery.
Spoiler alert: It performs more reliably than the button on some Chinese flashlights.
Testing 1-2-3…
Then I printed the rest in plastic just tonight, that was 4 hours of work to get the printer going for some reason.
Beamshots!
Neat and pretty!
