RD6018 RD6018W 60V 18A power supply is published
RD6018W feedback
The workmanship is 10/10, the accuracy is 10/10 (you can safely calibrate inexpensive multimeters using it), The seller is very pleasant, quickly answers any questions. it corresponds to the declared characteristics by 100%
www.aliexpress.com/item/1005001488070904.html
RD6018 customer review
Well packed, the box is a little crumpled, but everything inside is whole.
RD6018W customer feedback
Today I received the package. I ordered it on November 13, received it on December 8. The packaging is excellent, the box is made of foam. All functions are currently working. I recommend the seller!
Great job. Congradulation Riden guys!!!
RD6018W customer review
Great power module. Now it remains to collect and check everything. The order arrived in Ukraine in three weeks. I recommend the seller and the product.
RD6018W feedback
Day 21. Meest Express home delivery. Tracked all the way. Seller sent the same day. Everything works great. 10 stars to the seller.
Full order. I recommend!
Live for our factory and products, and you can get coupons in this live to get more discount when making the order
RD6018W feedback
I ordered the same kit for the second time. The package arrived in Kiev, Ukraine, in 20 days. As is typical for a RIDEN store, it was perfectly packed in a foam box. I am completely satisfied with the product.
What’s the difference between the S12A case and the S800 case? Ideally I’d like to get an RD6018 (or 24 when it’s released) in the smaller case like the S12D, as my desk isn’t very deep, and I’d be using an external power brick. Realistically all I’m really after is ~80W (4V 20A), coming from an old Dell laptop 130W power pack. Or would the DPS5020 be a better bet? I just like the form factor and extra control of the RD models more :slight_smile:
very good, thank you so much for your support
hope you like it and tell your more friends
come quickly, packed well
RD6018W review
looks nice, you can check the pictures
RD6018W feedback
First impression is a good quality product. The packaging is very good, the cargo is really fast, I don't know my luck. It arrived from China to Ankara in just 11 days.
RD6018 review
This appears to be a great product that you can control from different devices. Fuses can be easily replaced. It's a pretty compact unit, although it it a bit on the long side. I added shrink tube to the DC-out and cable hold-downs for a cleaner internal appearance.
RD6018W review
Very nice packed and received in good contion! It works well. I strongly recommend. Thank you..
RD6018W customs review
very pleased with the purchase. yet there is no sufficiently powerful power supply unit. if you need the ability to regulate thousandths of volts or amperes, then take the 6A model
Everything is super, home delivery, packaging is excellent! I recommend both the product and the seller! There is no clock battery included.
perfect, thanks a lot, it works great
RD6018W feedback
Very polite and courteous seller ! The shipment was carefully packed, and arrived in perfect condition, according to the description ! The device works perfectly. I recommend the seller as correct and responsive!
