Thank you, the beam shots are helpful. Any plans to test runtime on alkaline batteries? I saw an Eneloop runtime test on zeroair, but can’t find one for alkalines, except on the manufacturer’s site.
I just got the high CRI version from Amazon. This is a nice little light. I’ll be giving it to an elderly relative who needs a key-chain light but can’t figure out multiple modes.
Here is the runtime graph for what appears to be a regular/white Eneloop from ZeroAir. I don’t know if the high CRI version would be noticeably different but “about an hour” is decent for the amount of light this puts out.
Hot damn, that’s even better’n I thought! Nice flat output alllllllll the way ’til exhausted.
Now I gotta go get more?
Yeah, stabilization and runtime are great, but it will destroy your eneloops because you won’t notice they are empty until they are discharged too far. Or what is the voltage when the output starts dropping? Still above 0.9 V?
If you look at the graph from zeroair, he stopped the test at 2.5 lumens.
That’s clearly far dimmer than the regulated output. The battery is listed at 0.82v at that time.
That’s not optimal for an NiMH battery, but I’m pretty sure it won’t seriously harm it. You’ll get fewer cycles out if it, but Eneloops are so robust, even a 90% reduction in cycle life would mean several years of weekly charges.
Yeah, but it’s rock-solid flat flat flat flat flat output ’til you actually watch it dim down to nothing in probably only seconds. There’s no “100lm” at startup and then a gradual constant fade as the cell wears. I like that.
Using a LFP cell in my (Xeno) E03, I get about the same thing: constant flat output for almost the entire SOC of the cell, and then a noticeable dimming, letting me know I’ve got about seconds of light left. Not a problem because I only use it around the house, so it’s not like being stranded on a dark trail with no other light.
Hmm, so I wonder if that’s because of the cell’s flat voltage, or if it’s the same with even an alkaleak…
I think I’m fresh out of alkalines to test with, but I imagine it’d look vaguely similar to the NiMH runtime curve - nice and flat. That should be a function of the boost driver providing a constant current.
Nice teardown and photos! Did you ever get round to playing with the current set resistor?
No, I forgot about it in the midst of other mods I’ve been working on. I might have to give it a shot. Are you thinking higher or lower output? Seems crazy, but I had thought about dropping the output to around 3 lumens or so just got fun (and maybe to use as a reading light).
Maybe I’ll try a runtime as is and then one higher and one lower. We’ll see!
I’m thinking the same as you! I don’t have one yet though, bought too much recently
Ok, I just found an alkaline and I’m doing a runtime with it now while I top up some NiMH.
Is there a proof that Eneloops can be destroyed by discharging in a flashlight? I assumed that was the case until I got into a discussion with someone doubting it. I have no idea. Never got one below 0.8 V. They suffered, but I’m not sure if that’s not just because of their mileage.
Since alkalines can’t maintain voltage under load, I’m sure it will fall out of regulation much sooner. An NiMH AAA can handle the ~700mA load from this light without a problem, but an alkaline gets pushed to its limits and wastes a lot of its energy content in heat at that load. It also will be at high risk of leaking after such a hard drain.
Here’s a test of the similar Olight i3e EOS - excellent regulation on NiMH, but only 7 or 8 minutes before it falls out of regulation on an alkaline:
On the other hand, alkalines have pretty good capacity at low loads, so multi-mode lights or low output lights like the Fenix E01 can stay regulated for a very long time when producing only a few lumens.
Yup, you’re right. I’ll post up the runtimes later but the alkaline is anything but flat.
AA Cycler did a test on this. Leaving a flashlight on overnight repeatedly resulted in twice the rate of capacity loss and internal resistance increase compared to discharging to 0.9V, which is normally defined as empty for an NiMH cell.
http://aacycler.com/post/deep-discharging-nimh-lsd-cells/
I wish he’d checked final voltage of the test battery periodically to get an idea exactly how low it was getting, but I’m guessing around the ~0.6V that many boost circuits seem to stop working at.
Note that NiMH cycle life is rated by manufacturers per the IEC61951 test cycle. This is honestly a rather gentle test that only discharges by about 60% each cycle at a 4 hour rate, which will probably still be above 1.1V. If you look at AA cycler’s tests, he tests to 0.9V and at 500mA for a AA, which is roughly a 1.5 hour rate. Under that test cycle, he sees a few hundred cycles typically, compared to Eneloop’s 2000+ cycle rating.
If you go low enough, you will start to cause rapid damage to the battery. Energizer suggests (page 9 here) that at somewhere around 0V, the cell starts to suffer from irreversible internal reactions. Also, if NiMH cells are being used in series, the cell to reach empty first can still have current driven through it by the other cells, causing a voltage reversal that is even more damaging. Because of this, it is not uncommon to find batteries that have been used in sets in camera flashes, solar lights, etc, where the weakest cell suffered reversal and is almost completely dead, while the other batteries work fine.
In my opinion, the bottom line is still to charge the battery when it starts to noticeably dim, and not worry about it. You will still be getting far better performance, face less risk of leakage, and spend less money than feeding your light alkalines.
If you go low enough, you will start to cause rapid damage to the battery. Energizer suggests… that at somewhere around 0V, the cell starts to suffer from irreversible internal reactions.
I agree, when the light gets dim, change the battery
there is No reason to attempt to draw an Eneloop down to 0 volts, and I dont think it is possible in a flashlight, since they stop working around 0.8v anyway.
There was a report recently, that a Sofirn C01 can draw the cell down to 0.4v, IF the light is left ON… but if the light gets turned off, it wont turn back on unless voltage is at least 0.8v…
I see no reason to abuse an eneloop this way. If you really want to run a light at super dim, relatively useless brightness, just cause you like to count (uselessly dim sublumen) runtime… then use an Alkaleak…
I once had a meeting with a few Eneloop engineers (at the Panasonic office in Belgium) , and they said that deep discharge is worse than overcharge.
Here are the questions and answers: https://eneloop101.com/interview-with-eneloop-technicians/
Especially Question #16 onward
Hey, thanks, Lucky!
Yeah, that’s what I do. I’ve never had enough light output when the cells approached 0.8V and so was forced to recharge them. So, I’ll continue to not worry about it.
Thanks to you, too, ChibiM!
thanks for the interesting story
fwiw, #16 says:
“There is no real testing data to prove this point of how much % cycle life at certain voltage is lost etc. but a deep discharge will reduce the cycle life, this can be by 1%, but can be more as well.”
so, just FUD and nothing specific
now thats Real World
;) They didn't back up their claims, but I trust they know what they were talking about :D
