I’m thinking the same thing, Quad Thrower.
Hopefully will be compact.
Never knew Fireflies (Firefly?) had a second website.
Some quick measurements using 30t on all three lights. All three lights have the sbt90. From left to right. T9r, ft03s, k1vn90.
Brightness doing simple ceiling bounce at turn on:
T9r- 730 lux
Ft03s- 730 lux
K1vn90- 850 lux
Throw measurements 25 feet away:
T9r- 478
Ft03s- 546
K1vn90- 655
This is not a review. Just my quick take on the light. I haven’t played with the light yet. But so far so good. I like that it doesn’t look like your typical flashlight. The head looks strange how it tapers off smoothly until it reaches the body. The tail cap thread was really dry but fireflies did include a small tube of lube. Finish seems well, no sharp edges. Fits well in hand. And weight distribution is fairly even. I’m still unsure about the switch. It’s kinda hard to explain. There’s not much travel on the switch being you don’t need to press down to far to activate it. And there is barely a audible sound when pressing the switch. But because of the short travel, the switch takes a bit of pressure to press down. Not hard at all, but just different. You guys will see what I mean once your light arrives. Or maybe someone can better explain this.
Nice to see the T9R side by side with the K1.
How do they compare?
^ +1
Thanks for your impressions, how do they compare heat wise? From the shape of the lights I’d assume that the T9R would have the most efficient heat management, and that the driver would create less heat compared to the fet ones.
Is this about the store Brayn Gear. If it is BEWARE. Brayn gear is not on the level. Check out the ROT66 they have in custom lights They have arot66 what they are calling a S50. The light is listed for 219 dollars on sale for 77. Ask them why its a 219 dollar light. Then look at Specifications . Its the old bait and switch.
It shouldn’t. Because it is a thrower.
FireFlies, please, this has to be a quad SST-20 95CRI / quad Osram thrower :partying_face:
Please target above 300 kCd intensity with the SST-20 95CRI option.
I’d like something around the size of the TN40 or perhaps a little bit smaller. 4,000 lumens and 6-700kcd with good heatsinking for at least 3-4 minutes of sustained turbo.
lol, nothing too unreasonable then
My review of this bad boy is done! Check it out over at 1Lumen.com
PSA for those that don’t read my review: do NOT use long protected cells
Great review! I have the exact light except in black. I put a protected battery in the tube to compare length. I saw it was to long for my liking to screw the rail so on. Very glad I backed out especially after reading the review with the resistor damage by crushing. It specifically says unprotected cells for a reason.
I own several Fireflies, and this one is incredible when you fire up the turbo. For a one called light, it amazes me with its output!
Ok, an update on the “long cells” situation. I noticed a sticker on the accessories baggie that says “To fit 77mm 21700 remove tail spring put it into tailcap.” So I take that to mean if you’re going to use long protected cells that you remove the tail spring (pry it out with small needle nose pliers) and leave the already-installed spacer in the tailcap. Note that that means there’s nothing holding the spacer in besides pressure from the battery and the small driver spring. This did allow a long protected USB-C charging cell to be used. But then there’s not enough spring travel to use a non-protected cell. You should pick whether or not you’re going to use long cells and stick with that decision because removing and installing that spring isn’t very fun.
Is it just me or do SBT90.2 lights tend to have a second, inner hotspot? I’m noticing it in beamshots of the Fireflies T9R and the Noctigon K1, there’s the medium-small hotspot, then another, tiny circle in the center of that that’s quite a bit brighter than the rest of the hotspot. Can somebody with one of these lights confirm or deny?
Is it just me or does the OSRAM LED just eat battery charge like crazy?
I don’t know about this flashlight in particular but the OSRAM 1mm^2 are very inefficient at high current compared with the 2mm^2 or bigger LEDs. They are basically a better XP-E2 that won’t die as easily, but you wouldn’t expect a XP-E2 to remain efficient on turbo.
Output and voltage drops significantly over 10 mins, even the tint changes
I took measurements and posted here
*I sent my copper E07 back to Jacky in the US address for fixing because 3 things were broken and wrong and I am still being ghosted by him. I repeatedly messaged and emailed FF and Jacky, and always got ghosted. 2 years at this point and over $100 down the toilet. DON'T BUY FIREFLIES OR ANY OF THEIR NEW BRAND THEY ARE A BAD COMPANY. Do not do business with them. Buy from better people and companies.
A lot of lights with the 4040 pad White Flats are driving them at 6A+, that’s going to drain any cell very quickly.
