TS30 UK code :T2DTZRRZ
25% off
Any new news about the TS30A?
That bundled 21700 5000mAh shouldn’t be sold with the TS30S, please find something that can allow it to perform to spec. Sofirn sent it to me for review and it’s only slightly better than a Samsung 50E
The battery supplied with TS30S is a rewrapped Lishen LR2170SD. The most interesting specifications are:
Diameter: 21,7mm ± 0,2mm
Length: 70,9mm ± 0,2mm
Weight: 72g ± 4g
Nominal capacity: 5000mAh at 0.2C discharge current
Minimum voltage: 2.50V
Maximum voltage: 4.20V ± 0.03V
Standard charge current: 0.2C (1000mA)
Maximum charge current: 0.7C (3500mA)
Maximum discharge current: 2C (10000mA)
Initial internal impedance: ≤ 30mΩ
Thanks for that, Sofirn never provided those specs. Almost finished the tests
Thanks for confirming that the 5000mAh 21700 battery included is a Lishen LR2170SD.
I notice that there is a purple-pink wrap slightly visible underneath the Wurkkos rewrap. And it looks like the LR2170SD has a purple-pink wrap based on images on the web.
However, if the max discharge current is 2C or 10Amps, then this doesn’t seem to be the “right” battery for the Wurkkos TS30S, which uses SBT90.2 LED, and isn’t this LED supposed to consume more than 15 or 20+ Amps to get max brightness? Using a “10 Amp” rating cell would then sort of limit the max performance of the TS30S…
TS30S looks great, I’ve been wanting a light with SBT 90.
Would a 40 T battery give it max output?
No, a 30T will give max, but go for a 40T since it’s also got decent capacity. You’re only gaining approx 150-200 lumens using a 30T which isn’t enough to justify the loss of 1000mAh
Already been demonstrated on a Facebook group, looks about half as bright when used with a 40T
New code update of TS30S on Amazon US
Code: 3ASY5WFU
15+20 Coupon
2021-2-2 03:00 PST
2021-2-28 23:59 PST
New code update of TS30 on Amazon UK
25%code: LO8VDM7D
The new amazon code works!
Can we get a new code for TS30 for Amazon US please?
The Aliexpress code doesn’t seem to be valid anymore, could You please give us a new one?
Thanks!
Lux Perpetua-
I will buying the t30s in the next day or two via your amazon US link, so thank you do that!
But, because I’m so excited for it and can’t wait, could you maybe take a pic or two with T30s next to some other popular lights? A C8, ft03, ec03, anything like that?
Thank you !
@ Artiet59
For now, I can only offer a size comparison among Wurkkos flashlights.
https://budgetlightforum.com/t/-/62958/69
However, there’s a nice review on TLF. It contains a picture of the TS30S with Lumintop GT mini, Wurkkos FC11, Emisar D1s and Armytek Viking.
https://www.taschenlampen-forum.de/threads/wurkkos-ts30s-review.79885/
Artiet59,
Here’s another comparison:
FT03S - TS30S - XT45 - X9L
XT45 is very close to a C8 in size (almost same head diameter or just a wee bit bigger than C8’s head, but with a 21700 body — similar to Sofirn C8G / Convoy M21A body)
Thank you lux and d-t-a! Those comparison are perfect as I have the M21a, x9L, and ft03. I appreciate it very much. I also was comparing it to the measurements of the M21a and thought that’s probably the closest size head and length.
This will be a perfect in between sbt90 size light with my x9L and ft03s!
Is the TS30 battery the same?
