I have not used this particular film but I have used non-adhesive film on windows. One window stayed on perfectly but the other always wanted to peel in the corners no matter what I did. Eventually I mixed a little wall paper paste with water and used it very diluted. So far stays on well now.
The nonsticky stuff I always samwich between the front glass and the reflector.
Hell, even the sticky stuff, unless I want the ability to peel it off for instathrow.
What’s the best method to spread the beam on a SP40? Which film should I use?
There’s no “best”, only “best as to what I’m looking for”.
Lightly diffused will just “smear” the beam a bit, eg, to get rid of a hole/cross from a multi-die emitter, get rid of mild artifacts in a beam, etc.
Heavily diffused will turn even a thrower into a flooder and give a nice blanket of light, only not as edge-to-edge even or with as sharp a cutoff as an aspheric.
Then there’s everything in-between.
I put DC fix on a Quark 1AA Pro with a SST-20 swap. Minimal shape change.
Results of my experimentation: #7 is great for a headlamp/worklight like the SP40. It reduces the hotspot, though there is still some, and gives a more even blend from hotspot to spill. Tint shift is reduced too. Of course, throw is reduced too, but for near and mid-distance viewing, which is what a headlamp or worklight would be for, it is a great tradeoff. No more tunnel vision, and great general illumination. #4A is great for the XHP50.2 in the SP33v3. Finally, no more ugly and distrac…
Thanks Boaz! I almost tossed your note until I noticed the #5 in the corner. Shipped quickly, I’m just slow to thank……
I seem to be having trouble sending you a PM, but could you put me down for a few sheets of whatever is best for an H600c? It will also be used to diffuse a proper thrower into a more general purpose light. My paypal is [redacted]
Thank you!
Thank you!
Hi there, welcome to BLF! It’s not a good idea to post email addresses in public, so I redacted it. I also enabled PM privileges for your account so you can contact Boaz directly now.
Just wanted to say that it was a pleasure doing business with Boaz. I just tested out six of the diffusion films and a couple of the minus green filters, and posted the results over on r/Flashlight. I have to say that I’m really liking #12 and #7 (they are very similar to my frosted TIRs), and the minus green filters are pretty cool. This is my first experience with them. This was a good deal, and I encourage folks to buy a few and try them out. Thanks Boaz!
I’ll take 2 sheets of number 1. The name box turns red when trying to send PM, not sure what the issue is.
Uh-oh.
Probably like in “I The Robot” where, when their lights go from blue to red, they go on a killing rampage!
I'll take 2 sheets of number 1. The name box turns red when trying to send PM, not sure what the issue is.
Here's a quote from Mr. Admin to someone else, but it applies to you as well:
"Hi there, as a new user your account has private message limitations. Please continue to use BLF, and the limits will eventually be lifted."
Basically, the more posts on BLF you have, the more PMs you can send per day.
So… no Killer Boaz?
What a letdown…
Just wanted to say that it was a pleasure doing business with Boaz. I just tested out six of the diffusion films and a couple of the minus green filters, and posted the results over on “r/Flashlight”:https://www.reddit.com/r/flashlight/comments/oqylz4/test_diffusion_films_minus_green_filters/. I have to say that I’m really liking #12 and #7 (they are very similar to my frosted TIRs), and the minus green filters are pretty cool. This is my first experience with them. This was a good deal, and I encourage folks to buy a few and try them out. Thanks Boaz!
that's a very nice comment ...
Sent you a PM ... maybe my pm works :)
Uh-oh. Probably like in “I The Robot” where, when their lights go from blue to red, they go on a killing rampage!
or
I Robot
Just found my DC-fix from my last order. Cut out a piece for my H32w.
Did the trick, like I new it would.
Now the H32w is very comparable to the Manker E03II TIR (without difuser).
Has anyone figure out an easy way to cut a doughnut ? And just cover about a 1/4 inch of the outer ring?
Results?
Just found my DC-fix from my last order. Cut out a piece for my H32w. Did the trick, like I new it would. Now the H32w is very comparable to the Manker E03II TIR(without difuser). Has anyone figure out an easy way to cut a doughnut ? And just cover about a 1/4 inch of the outer ring? Results?
Easiest to use a decent compass and an extra fine pencil point or ink pen if it will take that, then just scissor it out.
I wouldn't buy a set just for this purpose, but gasket punches can be darn handy. I will tell you straight up that the quality of metal (and sharpening) in this kit and similar others is not great, but they generally work ok and would be fine for this. Not all sets have a center point like this one but that's the best way to go for accuracy (point is removable if you wish for other tasks). This set is a couple bucks more than others but it has more sizes, too. Disadvantage is the fixed sizes of the cutters. Put the film over a firm but forgiving surface (wood, hockey puck, hard industrial rubber) and give it a whack. Larger size first of course. There are nicer sets (better steel) from Lang/General and some much higher priced industrial brands but they usually just use a straight hex handle without the center point.
You could also use the light bezel as a guide for the outer diameter and then find a socket that suits and try to center it as best you can. There are some architectural drafting templates that might work, too..."crosshair" concentric circles that would only leave you with four small points to snip without a line.
And there are craft "circle cutters" out there but I think all of those have a somewhat large minimum cut diameter (basically a compass/trammel point setup with a cutting blade attached). If you have a compass that will take larger pen/sharpie marker bodies you could possibly put an x-acto knife in there.
https://www.amazon.com/ABN-Hollow-Leather-Punches-Gasket/dp/B07PQYRG9K/
I might see about some sockets, I have various sizes.
