Luxeon HL2X
Gotta see these things! Ordered qty 10 of the 3000K 80 CRI, qty 10 of the 400K 80 CRI, and 3 of the KW HHL532.TK.
For the KW HHL532.TK's, not sure what size, if they are 3535 or not.
They’re weird. More like a 3737 package with a 3030ish solder pad. Non-neutral thermal pad (cathode)
So they are a no-go on a DTP mcpcb it sounds like?
In a light with an anodized shelf or with special treatment with kapton or thick thermal epoxy a DTP will work. I think it’s still better than the dielectric being right under the tiny thermal pad.
Too bad, makes it useless for anything I would want to use it for. Oh well, the hunt for a good high output 90cri 3535 LED continues.
Mine shipped, should get them by the weekend. Sounds like some difficulties - standard centering rings won't fit and standard MCPCB's won't fit, plus the ground problem :FACEPALM: . I'll see if they will fit under 3535 optics, if so, might try an a multi-LED light like the MF01 Mini.
Just to be clear, the comments about 3737 and a non-neutral thermal pad should be in reference to the HHL532.TK (“Black Flat S”). So not too unlike the original Black Flat.
The Luxeon HL2X, on the other hand, is supposed to be a standard 3535 footprint that’s compatible with our existing 3535 stuff.
ah, ok thanks for the clarification.
Guess I will wait to see what Tom thinks of them before jumping in. Considering them for my EDC triple if they have higher output then the sst-20 and good tint.
Oops, my fault! Forgetting what I forgot... Time lapses are kill'n me...
Sux getting being old.
If this order took another week or 2 to arrive, I'd get them, totally forget why I ordered them!
Yup, datasheet shows standard 3535 footprint with isolated thermal pad.
Mine are coming today, FedEx. Mouser had a deal on FedEx or UPS 2-day for like $8. Besides the LED's, in this order are MCU's and FET's been running out of.
Looking forward to impressions. I ordered some 4090 but they are a couple months out.
JaredM will be sending me some 4000K 90CRI variants for testing. But perhaps someone else is quicker with that?
90 CRI's are not in stock. I have 4000K 80 CRI's and 3000K 80 CRI's delivering today, qty 10 of each. If you want a couple of each, I could send them to you. They are so cheap, at 72 cents each in qty 10. They are like 1/2 the price of SST-20's!
My order should be here Friday if the snow doesn’t delay it. The only HL2X that are in this shipment for me are the 4080s. They really are inexpensive… I hope they aren’t cheap! Will be testing them under a bunch of TIRs and reflectors. I’ll post my impressions. Jos, I’ll notify you when I get a solid ETA on the 90CRI versions.
Will be following the experiences with this led until then :slight_smile:
Well for me, these are a bust. Up at about 5-6 amps, turns blue, and lumens is about 850-900 at that point. The 4000K's looked warmer than 4000K (unless I mixed up the 4000K and 3000K, don't think so). I was using a black LK 5000 mAh cell, nothing crazy, but in a FET+1 modified Lumintop SD26 - probably 20 AWG wires, spring bypasses, mounted on a Maxtoch 26 mm MCPCB.
Took some pics, nothing special, but Photoshop is dead-spinning on me now so can't upload. Oops, good now:
I was drafting a long post earlier today but gave up on it. Figured I’d wait ’til they show up. I figured they’d act like the V2s and fall off a cliff at about 5.5A. These really are going to be well suited to triples. How’s the color consistency and tint? Green?
Yes, I did not have great hope that these are lumen/throw monsters (but 1000+ lumen would have been nice :frowning: ), but Lumileds is good in tints.
I guess a multi LED flooder of 5+ LED's on one cell would work. The tint looked pretty consistent but at the higher range of amps, it would get cooler, then higher still, turns blue. Guess a triple or quad would work with resistance.
Ran out of time for beamshots - snow on the ground, again, this morning and off to work. I'll double-check but the 4000K seemed pretty warm. I liked the consistency of the beam in a good thrower reflector, which the SD26 has.
