Sofirn 21700 5000mAh (Review)
I would not go out of my way to buy Sofirn batteries, I do like when they charge you $2-$3 and include one with the light you are buying.
Sure, you can do better, but it’s a very decent cell Sofirn are bundling for cheap. I’m impressed tbh
Thanks for the great review, Jacob.
Lishen LR2170SD, see my review of Sofirn‘s SF47T here:
https://budgetlightforum.com/t/-/65481
This battery can also be found in the Wurkkos TS30S and some bundles of the TS30. While this battery is great for lights like SF47T and SP35, it is not the best option for FET/DD lights like TS30 or TS30S taking advantage of high drain cells like a Samsung 30T/40T/50S or Molicel P42A.
I agree with Jacob that it’s a very decent and cheap alternative to Samsung’s 50E/G. Most of Sofirn‘s 21700 4000mAh batteries seem to be a Lishen LS2170SA. There are some with a recessed ring and some without, so there’s some variation in there.
Thats what I meant, I like it and I normally add one to my order.
Thank you.
Yes, that was a mistake to be sold with the TS30/TS30S. Here’s a comparison at 20A against the 40T. No idea whether they’ll change it, but I can imagine it’ll ruin reviews if they use that cell, already complaints surfacing of poor performance.
I will not give up encouraging Sofirn and Wurkkos to reach out for better high drain batteries. My guess is they are somehow bound into a long-term liaison with Lishen and DLG but maybe they are willing to rewrap some Molicels or Samsungs for a moderate price.
Are you certain it’s the LR2170SD? There’s a sale on 18650batterystore for cheap so might import some.
I was given the datasheet for LR2170SD (03BCEA5), so yes, it should be that exact model. I can mail you the datasheet if you want.
Did they change the bundled battery with the TS30S yet? I am looking forward to that light. I have a 30Q 18650 which maybe I can use with a sleeve to compare the performance.
Unlikely. They do not have anything better than Lishen LR2170SD or Sanyo/Panasonic NCR21700A. These cells work greatly up to 10A, maybe even 15A. For the TS-series you need something with more juice like Molicel P42A, Samsung 30T/40T/50S if you want to push it to the limit.
Is that something you’d be willing to share with the rest of us?
I am not sure if that datasheet is allowed to be made public. It is from Lishen and nowhere to find on the internet (at least I did not find it after long searching :-D ).
I won’t tell :innocent:
It’s not in English so all I found helpful was the charging and discharging notes
The most important specs:
Diameter: 21,7mm ± 0,2mm
Length: 70,9mm ± 0,2mm
Weight: 72g ± 4g
Nominal capacity: 5000mAh at 0.2C discharge current
Minimum voltage: 2.50V
Maximum voltage: 4.20V ± 0.03V
Standard charge current: 0.2C (1000mA)
Maximum charge current: 0.7C (3500mA)
Maximum discharge current: 2C (10000mA)
Impedance: ≤ 30mΩ
Maximum discharge current is actually 9.6A :slight_smile:
Thanks. Like you, I wasn’t able to find the one for the SD, only the SA.
Thanks sir, U saved me from buying a not very good battery! :sweat_smile:
I don’t think Sofirn use this same battery anymore. The one they’re using now seems to much, much better.
Not sure whether that’s still relevant given that @PiercingTheDarkness has reported Sofirn is now using a different battery, but I was able to find the Lishen LR2170SD (03BCEA5) datasheet here: PRODUCT SPECIFICATION Cylindrical Lithium-ion Cell LR2170SD(03BCEA5) (via: Lishen 21700-LR2170SD 9.6A Flat Top 5000mAh Battery - Grade A Genuine – Liion Wholesale Batteries).
I just archived it in case it eventually goes away: Web Archive copy
