I planned to order at Farnell but that’s in UK, do they ship to US at reasonable cost ? Indeed stock has disappeared at Mouser, last time I looked there was stock , I should hurry to make my order.
I added the suggestion from Gchart :
- only one via for the flashing pads because I couldn’t fit more without moving a lot of things
- gnd in the middle of the pads
edgecut at 22mm
Thanks
Yeah I don’t exactly know how it is done in the Unicorn 1.0/Geko, I thought I read that Vsense is read by the ADC, with some wizardry to increase resolution, then a PID loop to control the current, not sure though, maybe it’s something else.
I saw those at Farnell and some over in Asia. Every place wanted like $40+ in shipping fees to get them here - no thanks! Well, I guess Farnell “only” wanted £25 in shipping. I guess I’ll wait for my Mouser order this summer. I’ll try to make my 10 on hand stretch out until then.
I’ve been away for a while… nice to see that your work with 1-series is catching on.
Maybe I’m being a stickler, but the 1 series doesn’t need three flashing pads. It’s needs GND and UDPI, and the MCU needs to be powered. If I don’t have the driver powered already I just connect V+ from the Xplained Nano to the battery spring with a crocodile clip.
Another thing… you mentioned shortage of 1616s and you see them on Farnell UK. The US branch newark.com has them in stock (selling fast though), do you still have to pay that much postage if you order through Newark? They do refer to UK stock but you might be able to get around the shipping? I can’t order from Farnell UK directly myself, but in Sweden we have a components shop that allows anyone to order from Farnell UK and only pay local Swedish postage from the Swedish shop. I just got a bunch of 1616s delivered. Perhaps there is a similar service in the US for Newark if you can’t order from them directly?
I think when I tried Newark, it was quoting me outrageous international shipment fees since the stock was going to come from UK.
I agree, you don’t need VCC if the MCU is powered, but what if you want to flash a driver that isn’t installed in a flashlight? Or it’s not able to be powered when you have access to the flashing pads (most flashlights)? In my mind, it’s no more difficult to include all 3 pads and it gives you more flexibility. Just my 2 cents.
Hmm, and here I was wondering if it mattered if the V+ for flashing was connected before or after the LDO, if like, the MCU was powered from a lower voltage (ldo voltage) than the UDPI signal it would cause issues (maybe a stupid question…).
FWIW, when making one of my programming keys, I accidentally put the resistor inline with the VCC line instead of the UPDI line. If I remember right, the computer didn’t even recognize that the MCU was connected. So I just connect the pins directly at the MCU, without anything like LDOs or diodes in the path.
Just as I wrote, I have V+ from the Xplained Nano connected to the battery spring by a crocodile clip. The Xplained Nano powers the MCU. You did write you made the change to make layout easier, I just added this because layout is even easier with two pads instead of three, it works fine for me.
Yeah lol, a few moments after I ordered, I also wanted a buck IC, some 9000 in stock in the morning, then zero in the afternoon when I placed my order, plenty of other ICs have poor availability too.
It’s been a while since I’ve played with the TCD, I should do that again. Let me know if you run into issues and I might be able to provide some pointers or run some tests on the Xplained Mini dev board.
I hate to break it to you, but it looks like Anduril will need some (hopefully minor?) updates/customizations to make TCD work. If you check out page 250 of the datasheet you’ll see how the TCD works with CMPxSET and CMPxCLR. It’s opposite of how we normally think of PWM. If you set CMPxSET to 0, the LED would be fully on. If you set it to 255 (8-bit) or 1023 (10-bit), then the LED will be fully off. You’ll notice that in my test code, I subtracted the desired PWM value from the period to get the inverse.
Also… you need to tell the TCD to synchronize any time you make a CMPxSET (or CMPxCLR) update. That’s the “TCD0.CTRLE |= TCD_SYNCEOC_bm;” line in my test code.
Pretty much anywhere PWMx_LVL is used, it’ll require a small update. After grepping around, it looks like most of the changes are going to be in fsm-ramping.c. There are also a couple lines in fsm-main.c and spaghetti-monster.h. None of the changes should be too terrible. If you want, I could make the changes if you’d like to test them.
