I haven't done a side-by-side comparison of the Noctigon K1 (SBT90.2) vs the Wurkkos TS30S (SBT90.2), but I've made some beamshots from the same distance here in these videos (the flashlights are in max brightness levels).
For the videos below, the oppposite building is around 150 meters or 400 feet away from the flashlight's position.
1) Wurkkos TS30S (SBT90.2) beamshot
2) Noctigon K1 (SBT90.2) beamshot
3) Astrolux FT03S (SBT90.2) beamshot
Per my testing, the Noctigon K1 (SBT90.2) appears to perform very similar to the Astrolux FT03S (SBT90.2), following beamshot shows TS30S vs FT03S
4) Astrolux FT03S (SBT90.2) [left] vs Wurkkos TS30S (SBT90.2) [right]
in the following video, the distance of the flashlight and the opposite wall is approximately 18 meters or 60 feet
5) comparing the Noctigon K1 (SBT90.2) [left] vs Astrolux FT03S (SBT90.2) [right]
The two separate videos of the Wurkkos TS30S and the Noctigon K1 (SBT90.2) were so similar that I could stop the video at almost identical scenery locations and compare the beams.
I have gained useful knowledge along with details for interesting lights from your helpful posts and videos in this and many other threads. Thanks again.
I’m tempted to just catch/release one to see the SBT90 in person. It’s just so strange how rare it is to find online considering how inexpensive it is for the emitter and has Anduril.
I had a hard time selling mine actually, hence the huge loss. I had something else I wanted to buy so just needed to unload it. If you can play waiting game it’s maybe not as bad
Anyone else find the usb charging port in a weird/uncomfortable position?
I wish the handle was slightly longer, my fingers naturally rest on the off/on switch and the usb charging port cover when using the light.
Does not feel natural. I’m always worried I’ll remove the port cover or lose it while in use. A slightly longer handle would fix the problem easily. Shouldn’t make too much of a difference in carry or pocketablity since the light is already so big.
I mostly use this light as a dedicated thrower due to the placement of the usb charging port cover so it doesn’t make a huge difference to me. A redesign would probably make this light something I would carry more regularly/use regularly.
