I don’t think it makes any difference if the LED is PWM controlled or current controlled as far as looking at it is concerned.
Too bright is too bright no matter how you get there.
As Scallywag said, a too slow PWM coupled with a short duty cycle makes for a very unpleasant light to use in almost any circumstances.
Some lights have truly awful PWM running in the 100Hz to 300Hz range with 5% to 25% duty cycles.
One of these will cause eyestrain and headaches for me and many individuals. Yet some folks seem immune to truly awful PWM.
There are several threads about PWM that are buried in the general info category.
I made a video of the LT1 PWM charactistics and duty cycle here:
That might help explain the relation of PWM to brightness.
And another looking at PWM vs camera shutter speed.
CNCman,
PWM and the duty cycle is baked into the firmware.
So unless you can get hold of the code and flash the driver you are stuck with the OEM settings.
In another thread TK told me that the 5K PWM at the lowest levels was to provide enough ” on time” pulse to light the LED.
I (think) I can detect PWM into 3K realms if the conditions are right.
Total dark and spinning fan blades that I can vary the RPMs.
5K and up and I’m good.
All the Best,
Jeff
Is it possible to modify a Halogen light bulb spotlight to use a XHP 70.2 led. I am concerned the reflector is not designed correctly for a led.
A good friend uses a cheap Q beam on his early morning fishing trips in his Bay boat to navigate to open waters. I thought maybe it could be improved since he is disappointed in its output. I wanted to dig into it since my operating table is vacant.
Yeah, most likely the reflector is not shaped correctly for an LED. Think about where the light is being emitted in each case - and therefore where the reflector’s focal point should be. For an LED, it’s almost exactly at the bottom of the parabola. For a halogen bulb, it’s going to be some distance inside the reflector.
I have seen several Surefire lights that include a clip that makes it go bezel up when stored in pocket. What are the practical uses for such a configuration?
I know for some small lights you can clip to your hat and use as a pseudo headlamp but what of larger lights?
The lighting element and the switch are two separate pieces. So yes, you can mix and match to create a lighted forward clicky switch. As far as whether you can buy a pre-made lighted clicky switch, I don’t know. They’re not very common on factory lights.
At the time I ordered, CSLMN1.23 C8+ was out of stock, so I ordered a CSLNM1.TG C8+ 12 mode to swap the .23 into but I just learned the forward voltage is less for the red Osram. I’m new at doing swaps and figuring out drivers so what driver should I use in place of the 12 mode driver I ordered? I want to probably order stateside because I have a certain time frame in mind for a project (4th of July…). So which driver can I use turbo or 100% for a good bit without frying the red?
I’m not sure Simon uses different drivers for those LED’s, his drivers arent that sophisticated.
i think you should be fine, maybe a good google search will give both currents.
The Convoy 4x18a flashlight sbt90.2 can be purchased with or without its 18650 batteries,
I don’t know anything about the included batteries, and I am wondering if it would be worthwhile to purchase them separately for a performance standpoint?
It looks like Convoy is offering 4 of the Liitokala 3500mah cells for an extra $18. I’m not too familiar with that particular cell and I can’t find any reviews or tests on it. All I can say is it would fall in the “high capacity” style which looks like it would be fine for this light. Does anyone know the driver type of the SBT90.2 version? If its a FET driver you might be able to squeeze out some more lumens, but only when measured. Its doubtful you would see the difference with your eyes.
Those included cells should be fine.
