Finally I put together a kit. It turned out to be a nice beautiful and useful laboratory power supply for my radio workshop. The unit arrived at 65V 12.3A.(you can still get 18A output on RD6018 even it is 12.3A from the PSU)
Good product, good seller. Detailed explanation on the YouTube channel I bought 2 of the same product. RD 6006 and RD 6018 both products are of very high quality. The product arrived quickly and is very, very well packaged.
Everything is very neat, high quality. Well done just the way it should be. It's a little silly to talk about the speed of delivery. In this case, it did not depend on the seller. Of course, I recommend it for purchase.
I collected everything for an hour. The block is whistling. To stop whistling, you need to put a resistor from the kit. In general, like everyone else, it whistles and works =)
The converter with the housing came to me in good condition and without any additional charges. visually everything is really good quality and it looks like everything will be OK. I am very happy with my purchase
I ordered a complete set: RD6018W with an S800 case and an S-1000-68 power supply and assembled it. Everything works fine. The packaging is branded, especially the RD6018W module, so iPhones are packed.
Well packed. I want to use it with a 1000VA toroidal transformer 50VAC (70VDC) to have less noise, it fits perfectly in S800 case.Nice soft buttons. WiFi tested and works good. Battery charge datalogger is ok, but it only exports to Excel.
yes, for RD series, please use the battery charging terminals, it has protection function, for DPS series power supply, you must check the wiring before turn on the output, it has no reverse protection.
hello, when you get part of your order, do not worry, you can check your order to see if there are multiple packages to send your order, or you can contact us to let us help you, no need to make dispute immediately
