【ツ】Wurkkos WK01/WK02 Sales Thread (US/DE codes available again)
53 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 month 1 week ago
Update:
New codes for WK01 / WK02 on Amazon US, see updated OP.
TimMc
TimMc's picture
Last seen: 37 min 29 sec ago
Wurkkos WK01 SST20 4000K AAA forward clicky with Low, Medium and High modes.
WK01 SST20 4000K arrived today! I ordered it from the Sofirn Official store on AE.
I like the WK01 more than my i3T because of the 4000K tint and smaller size.
Are the drivers for WK01 and WK02 different?
Muto
Last seen: 1 hour 25 min ago
Gonna say yes drivers are different,
Got the WK01 and tried to put the head on a Sofirn PF04, Thorfire PF04 and will not work, head is shorter, threads different depth.
I know people will say “just make a contact ring” but that would not be a good idea as I did put a LifePo 10440 in the WK01 and the modes just do not change and it really did not get much brighter so higher voltage is probably going to kill the driver with no gain, no upside.
Flashlight really works well at the recommended voltage though and the tint is awesome! Could probably get away with primary lithium AAA which is usually around 1.75-1.80 volts and may see some increase in output.
Do wish it had mode memory, always starts on moon. Sometimes I need it to start on high like in daylight use under car hood etc.
HTH
Keith
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
TimMc
TimMc's picture
Thanks! This gave me the courage to try an INR10440 at 4.2V in the WK01.
I found it difficult to get it to switch mode from Low to Medium and High while using a 10440. It looked like it was stuck on Medium.
I had to rapidly momentarily press the button forward to change from Low to Medium and High and then click it in. If I tried to slowly click between modes it remained in Low.
The beam looks nice on high with a 10440. It seems slightly brighter than an i3T on High with a 10440.
10440 Low is like AAA Medium
10440 Medium looks 30% brighter than AAA High
10440 High is looks 30% brighter than 10440 Medium
Wurkkos WK01 SST20 4000K vs Olight i3T
If you run it on High with a regular AAA for a minute, that’s about how hot it gets when running it on High with a 10440 after a few seconds. I wouldn’t recommend using a 10440. Something might burn out…
TimMc
TimMc's picture
Would the 3V2 indicate that it supports 3.2V and that the WK01 and WK02 may be using the same driver? Cool
@Wurkkos: Thanks for not using red loctite! It’s much easier to play around with the flashlight.
Barry0892
Barry0892's picture
Last seen: 2 days 10 hours ago
Interested
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
Lux-Perpetua
Update:
New promo codes for Amazon US, see updated OP.
Just in case, should you have problems with the codes:
Sometimes it needs some hours before the actual promotion becomes active. So, please try again a bit later if it's not working already. Wink
ryukin2000
ryukin2000's picture
Last seen: 2 weeks 4 days ago
Lux-Perpetua wrote:
Update:
Sometimes it needs some hours before the actual promotion becomes active. So, please try again a bit later if it’s not working already. Wink
hey Lux, i tried the aliexpress code for the WK01 4000K and it doesn’t recognize it. has it expired?
Lux-Perpetua
I will try to get a new discount code for AliExpress. Smile
ryukin2000
Thanks.
Lux-Perpetua
New codes for WK01 and WK02 on Amazon US, see updated OP.
Beamshooter
Last seen: 2 weeks 2 days ago
Bought four FC11 in 4000k and 5000k versions and I am pretty happy with these flashlights.
Now I want to upgrade my EDC kit(s) with 2 or 3 WK01. Is there any chance to get a discount code for amazon.de?
Lux-Perpetua
I will check with Wurkkos to get us a new discount code for Amazon DE.
Lux-Perpetua
Beamshooter wrote:
(...) Now I want to upgrade my EDC kit(s) with 2 or 3 WK01. Is there any chance to get a discount code for amazon.de?
OP is updated with new codes. Smile
Beamshooter
Amazing. Thank you!
Edit: Tried to order with the code, but amazon says code is not valid…
Edit 2: Code is now working and price is 11.99 Euro! Thanks a lot!
Gunga
Gunga's picture
Last seen: 10 hours 51 min ago
Can we get it on Amazon Canada?
Lux-Perpetua
Beamshooter wrote:
Amazing. Thank you! Edit: Tried to order with the code, but amazon says code is not valid... Edit 2: Code is now working and price is 11.99 Euro! Thanks a lot!
Ahhh...besten Dank für die Info! Wurkkos sagte 20% Discount, so dass es eigentlich € 12,79 statt € 11,99 sein müssten.
Falls Du Dir die WK02 auch noch kaufen solltest, sag mir mal bitte Bescheid, wie hoch der Endpreis ausfällt. Danke!
I will ask but that's one of those questions only Wurkkos can answer. Would Amazon US be an option for you? I suppose it would add quite some shipping cost, right?
Beamshooter
Price for the WK02 is 14,39 Euro
Beamshooter
Ahh, found out why. The code works together with the 5% coupon on Amazon. WK02 is 13,49 Euro with the extra 5%.
Lux-Perpetua
Thanks a lot! So, I will update the OP again since it is unforeseeable if Amazon will keep available those 5% extra discount.
defloyd77
Last seen: 10 hours 42 min ago
The Amazon US codes no longer seem to work.
Tater Tot
Any chance of a new code for Amazon.co.jp?
