Is the SBT90.2 light made yet?
Last I read Simon was still having driver being Worked out
Anyone know why Convoy models very rarely get a waterproof rating?
Got a customer asking what rating the Convoy L21A has……any help?
Likely ’cause most ratings would be made up.
I worked at a place where I was charged with defining specs of POS equipment. “Point-of-sale”, but also the other kind, after I saw the innards.
Anyhoo, I asked for the test-spex. Min/max RH, max altitude, temp tests, etc. “Make ’em up.” Huh?? “Here’s what our competitors have for their equipment. Copy those spex.”
So pretty much everything was 10%/90% RH (non-condensing), –40°F to 120°F, 25,000ft ASL, etc.
Doubt the competitors did any tests on their equipment, either.
So… most lights have O-ring in the usual spots, rubber-boot switches, so they should be good for soaking rain and even dunking in a bucket or pool, but without actually paying $$$ to a test-lab to put actual light samples through actual tests, it ain’t happening. And O-rings wear, so those spex would only be good with new O-rings, not worn ones. The O-rings in my E03 pretty much turned to goo, and that’s with factory lube, nothing that I added. I don’t intend on dunking ’em anytime soon, but dropping one in a pool or into a toilet should be survivable (if yicky), even with the goo-ring.
A diving light, etc., with 2-3 O-rings should be that much more waterproof, but I doubt any are tested except informally.
Ask Markus to take one snorkelling.
….soooo I’ll just say yes lol
Thanks for the reply.
I think when I’m selling them I should test each one for 30 min or so then I’ll get an idea.
Rubber-boot switches should be good, but I’m not sure about the metal switches, how well they’re waterproofed.
Sacrifice one in distilled water (no cell inside) and see if there’s any ingress overnight or so. DW would evaporate right out with no residue.
I think Simon said the metal ones aren’t waterproof
I’ve tested all my reviewed Convoy lights (but L6), all of them not leaked after 2 hours underwater…wait, no. M21C leaked. I was wondering that too, Convoy could get extra buyers with that IPX8 mark, but I guess Convoy is just honest, something like: “We think our flashlights are waterproof, but we are not sure, we haven’t tested that. But you can”
Btw, here is my L6 GT-40 review: [Review] Convoy L6 diode GT-FC40 90CRI
A friend ask me a small good zoomie cigar style light but can’t suggest any.I Hope Convoy develope it
Quick search review say that it’s not real throwy light by the TIR
He asked me aspheric lens light,but now don’t want go out the thread
Ah, yes, that is true, but you’re not going to get much throw for a small size like that in any zoomie.
Doesn’t good Osram 1mm on small Asperic lens? I had zoomie with old xp-e2 that throw nice.
My best zoomie does about 700 kcd - modded a Xanes X915 with a OSRAM W1. The 1504 with de-lensed SBT90.2 does about 525 kcd, and the B158 below does about 300 kcd with a SBT90.2.
Not very pocket size light
So you want a Zoomie? Go Big!
It's all relative, but yes, a pocket/EDC zoomie is practical as well. I would like a 18650 tube (~25 mm) diameter zoomie, but it must have an e-switch and can run Anduril2. The S11C I got came with a 351D, and doesn't look easy to driver-swap, so not my ideal EDC zoomie. Still look'n, though I got some older 16340 and AA size zoomies, actually much preferred for our backyard use with the dog, since a zoomie has such a narrow beam, we're not lighting up the neighbors.
Really wish Simon would come up with a e-switch pocket zoomie because we know his would be quality - lots of junk zoomies on the market, though Simon doesn't seem to do much with e-switches - shame because it has really kept me away from Convoy's. He needs to catch up with the times.
…Doesn’t good Osram 1mm on small Asperic lens? I had zoomie with old xp-e2 that throw nice.
Dear Alen,
My first advice is don't pay attention to (with all due respect) spoilsporters, they may argue this or that but… do you really care?
If you are looking for a stealthy thrower, aspheric is the way to go. However, the best of zoomies is their flexibility, and the quality of their beams. The perfectly intensity-uniform blanket of light when on flood makes an aspheric or plano-convex flashlight a top choice for close-up work. I also love the perfectly focused “batsignal” trait of zoomies, by the way (let's you see the shape of the :-) led die).
So, if you like 'em go ahead. There's so much lack of love (or even hate) in zoomie or convex lens flashlight territory that it's easy to see the consequences: zoomies or aspheric flashlights are scarce, and lots of them low quality. At the same time, this is a vicious circle, because unless manufacturers make good zoomies how is people going to feel like buying them?
By the way, last time I bought the UltraFire SK98 @FastTech it still was “nearly acceptable” (2018/12/18). The SK98 is a great design who would thank that some manufacturer would grab it and build it with quality: solid pill with 2+mm thick metal base under the led MCPCB and completely revamped switch assembly (the stock one is a mod unfriendly mess).
Hi Barkuti.
My point is that I can’t find a good ready-to-use “pocket jeans” zoom light design.
That’s why would be nice if a quality budget brand like Convoy made one.
Yes SK98 can be a good host but always after modding.
Mine from FT had LB Led, cheap driver and I changed them.
I don’t think all buyers want to do that. Q.C often disappoints with unknown brands.
As for only the design style, I liked the old sk58 more
Maybe check out this thread for ideas
I recently did a review on a budget priced mini zoomie (TactFire TS-1) using the light re-kindled my interest and fascination with zoomies, and made me more aware of how useful they can be, going from a wide even beam with no hotspot - to a long throw beam with less spill. Earlier this year I found interest in the UniqueFire 1405, 1406, 1504 and more recently the Brynite B158, but hadn’t bought any of them. I have a few older ones: an SK68, a TrustFire Z8, an Aleto (Zeusfire clone), M-Flare Reb…
You forgot to post the link
Simon’s got some nice boost drivers in production and/or development for the FC40, and it sounds like a high-powered buck for the L6-SBT90.2? Wonder if anyone will be able to adapt Anduril to them… I’m sure they won’t have ATTinys to begin with, so it would probably fall to gchart or someone.
