As with the H3 headlamp, yesterday I took a change to go outside and test the Wuben D1, see how the beam behaves outdoor.
And as with the H3, I also got impressed! Specially with the type of beam of the D1.
If on the one hand it is quite floody, on the other hand has a defined narrow beam in the center, due to the type of TIR it has.
Below I show some comparison photos and also some beamshots from it.
Comparison with the Odepro TM30 (that has XML2 and a deep slightly orange peel reflector), on the right:
Some beamshots with the 4 levels, at different distances. It reached more than 100m, although I wasn’t able to see much more than that due to the moist weather at night.
I think it’s a gimmick that Wuben is marketing the powerbank functionality of the battery.
To begin with, I don’t like nonstandard batteries. I also really don’t want a powerbank that also has exposed + and - contacts of an 18650 laying around. But the fact that it’s part of the marketing of the light is just ridiculous to me.
Hum, so far Wuben is not advertising the light as such because it is not out yet.
I did put that info on the title of the thread.
If you think is is misleading or distracting, I may change it, but the package is supposed to include such cell anyway…
So far I didn’t see or received any info that the light will be adverstised with such emphasis.
Is the battery standard size, or overly long? I’ve got 18650s that are slightly long and still fit easily into most lights, and some that are rather long and limited to only a few lights with enough length inside to fit. My E05 has a monstrously long come-with 14500 that only fits the E05 and no other lights, but regular cells can still fit with its long-enough springs.
So… will the cell fit other lights, and can the light take regular 18650s (even unprotected flat-tops)?
Ahah, the “tablecloth” is a neck gaiter They sent me one some time ago with a flashlight for review (I guess it was the E19). Since then I try to use it on these reviews
About the battery size, as I put above, it is a bit longer than the normal “protected” cells, even the Wuben ones, which are long already.
I can tell that the D1 takes smaller batteries - unprotected, flat top - as the Sony VTC6 or the Sanyo NCR18650GA. But I didn’t try the ABT3400T cell on many other lights, though.
I can tell that it fits the Nitefox UT20 (whose cell is just slightly smaller), but I don’t have other “un-modded” flashlights on me in which I can try it.
I would say that it will fit a Wuben TO46R, a Zanflare F1, but I am not sure how well it will fit in Convoy S2+, as example.
I’ll check it next week and will let you know here :+1:
And yes, that 14500 cell is almost only suitable for the E05 (eventually to the Skilhunt M150, but without certainties). :weary:
Looks like a cool light. Any idea what’s the price and when it will be available?
Yea, I hope Wuben listen to your feedback regarding this:
1 – Align the Wuben logotype/battery polarity engravings in the tube with the switch button when the tube is all tighted in.
4 – The User Interface: I think it would be preferable for users to have a double click to Turbo from ON and OFF, and always have a triple click for strobe, either from ON or OFF.
Yup, I hope so, that they can “change/correct” those aspects. However, I wouldn’t put much faith on changing the UI, this seems to be their standard UI recently.
As for the price and date of release, I didn’t get any information on that. I assume it won’t take long to be released, but can’t tell about an exact “time”.
I’ve been testing and using it during the last days and yes, it is a responsive and reliable light so far. I have some “habits” from other lights that sometimes I use in this one (double click to turbo ) and ends up not doing what I want. But apart from that, it seems a solid flashlight
Wait a sec… by “fainting”, do you mean the lit switch is one of those “breathing” ones, that glows dimmer and brighter over a few seconds?
Gotta say, I HATE those, to the point where that’s an instant dealbreaker for me if always on. They’re just creepy.
I’d rather turn the damned thing off completely (eg, the original SC31) than have a creepy “breathing” light shining on me all night. And if I gotta keep it off, what’s the point?
I fail to see what’s wrong with either just a constant very dim light (best if RED than blue or any other color), or a beacon type, a quick blip every now and again.
Yes, by fainting I mean that “breathing” button
It can be enabled/disabled, of course, but it acts that way.
I prefer the blue instead of green (as the E12R has), but I agree that a red indicator light would be better.
Well, but for that you can try the GT Nano, whose light is red and so dim that it is almost unnoticeable
Good review MrB thanks. I like your reviews because they are thorough - some reviews just do the same thing over and over with very little useful info, you on the other hand delve into things much deeper. I don’t care for videos just shining it down a path etc with no commentary or photo’s.
My drive in the reviews is to show what the flashlight does while being used for the purposes it was built, and also to show how it behaves, knowing that different people have different tastes and needs!
I can’t go deeper in some technical aspects such as lumens or candela measurements, so I try to compare how it looks like along with others and also how it performs in my “eye-measurement”
I’m glad it is helpful and that the hours invested are appreciated
Thanks again :+1:
Hum, I am not sure if it is a 6500K, I would say between 5000 and 6000K instead.
But tonight I can compare it with a cooler tint so that we can see that.
I wasn’t able to reach the LED. Yesterday I tried again but I don’t have the appropriate tools on hand to do it, so I may try it later.
I am not sure if the bezel is press fit or if it is glued because I wasn’t able to take it out. But I when I am able to do it, I’ll post it here
As promised I made some comparison beamshots between the Wuben D1 and some other flashlights in the range of 5000K to 6500K.
Here are the “results”:
From Left to Right, Vs:
Convoy S2+ XML2 U2-1A 65000K
Jaxman E3 Nichia 219C 5700K
Olight Warrior Mini SST40 ???K Wuben D1 Osram P9 Cree XP-L HI 6500K (where th big toothpick is )
Wuben TO50R 4x Samsung LH351D 5000K
Wuben TO46R 3x XP-G3 5000K
FW3A 3x XP-L HI 3D 5000K
Convoy S6 3x Luxeon V 4000K
Convoy S2+ 3x Luxeon V2 3000K
It is definitely a bit cooler than some 5000K leds, but it is not as cool as the 6500K ones! It person, while taking this photo, it seemed “pure” white against the surface I was using!
The photo may be a bit tricky in some aspects but I guess they show more or less where the Wuben D1 is in terms of tint
Thank you MascaratumB for this great comparison shot. Indeed, it does not seem to be 6500K but closer to 5000K. Still too cool for me but I’m a tint snob…
Something I really, really, really like about this light (and might have to buy it just because of this feature) is the lighted switch. I love being able to reach my flashlight on my night table or tent pocket in pitch dark. I hope Wuben will put this feature on all their new lights.
You’re welcome and I’m glad it helped perceiving where it “locates” itself in the spectrum
About the lighted switch, I get what you say, it is easier to locate the flashlight in the dark in a much better way! They also have it in other lights (E12R comes to mind, and others eventually).
As Lightbringer mentioned, I too preferred a different colour on the led indicator (red) but the fact is that it works as it is
The lighted switch is in my opinion the only thing missing on the T050R to make it perfect. I don’t know if you like it as much as I do but what a fantastic wall of light, pur high CRI joy…
