Yup, I hope so, that they can âchange/correctâ those aspects. However, I wouldnât put much faith on changing the UI, this seems to be their standard UI recently.
As for the price and date of release, I didnât get any information on that. I assume it wonât take long to be released, but canât tell about an exact âtimeâ.
Iâve been testing and using it during the last days and yes, it is a responsive and reliable light so far. I have some âhabitsâ from other lights that sometimes I use in this one (double click to turbo ) and ends up not doing what I want. But apart from that, it seems a solid flashlight
Wait a sec⊠by âfaintingâ, do you mean the lit switch is one of those âbreathingâ ones, that glows dimmer and brighter over a few seconds?
Gotta say, I HATE those, to the point where thatâs an instant dealbreaker for me if always on. Theyâre just creepy.
Iâd rather turn the damned thing off completely (eg, the original SC31) than have a creepy âbreathingâ light shining on me all night. And if I gotta keep it off, whatâs the point?
I fail to see whatâs wrong with either just a constant very dim light (best if RED than blue or any other color), or a beacon type, a quick blip every now and again.
Yes, by fainting I mean that âbreathingâ button
It can be enabled/disabled, of course, but it acts that way.
I prefer the blue instead of green (as the E12R has), but I agree that a red indicator light would be better.
Well, but for that you can try the GT Nano, whose light is red and so dim that it is almost unnoticeable
Good review MrB thanks. I like your reviews because they are thorough - some reviews just do the same thing over and over with very little useful info, you on the other hand delve into things much deeper. I donât care for videos just shining it down a path etc with no commentary or photoâs.
My drive in the reviews is to show what the flashlight does while being used for the purposes it was built, and also to show how it behaves, knowing that different people have different tastes and needs!
I canât go deeper in some technical aspects such as lumens or candela measurements, so I try to compare how it looks like along with others and also how it performs in my âeye-measurementâ
Iâm glad it is helpful and that the hours invested are appreciated
Thanks again :+1:
Hum, I am not sure if it is a 6500K, I would say between 5000 and 6000K instead.
But tonight I can compare it with a cooler tint so that we can see that.
I wasnât able to reach the LED. Yesterday I tried again but I donât have the appropriate tools on hand to do it, so I may try it later.
I am not sure if the bezel is press fit or if it is glued because I wasnât able to take it out. But I when I am able to do it, Iâll post it here
As promised I made some comparison beamshots between the Wuben D1 and some other flashlights in the range of 5000K to 6500K.
Here are the âresultsâ:
From Left to Right, Vs:
Convoy S2+ XML2 U2-1A 65000K
Jaxman E3 Nichia 219C 5700K
Olight Warrior Mini SST40 ???K Wuben D1 Osram P9 Cree XP-L HI 6500K (where th big toothpick is )
Wuben TO50R 4x Samsung LH351D 5000K
Wuben TO46R 3x XP-G3 5000K
FW3A 3x XP-L HI 3D 5000K
Convoy S6 3x Luxeon V 4000K
Convoy S2+ 3x Luxeon V2 3000K
It is definitely a bit cooler than some 5000K leds, but it is not as cool as the 6500K ones! It person, while taking this photo, it seemed âpureâ white against the surface I was using!
The photo may be a bit tricky in some aspects but I guess they show more or less where the Wuben D1 is in terms of tint
Thank you MascaratumB for this great comparison shot. Indeed, it does not seem to be 6500K but closer to 5000K. Still too cool for me but Iâm a tint snobâŠ
Something I really, really, really like about this light (and might have to buy it just because of this feature) is the lighted switch. I love being able to reach my flashlight on my night table or tent pocket in pitch dark. I hope Wuben will put this feature on all their new lights.
Youâre welcome and Iâm glad it helped perceiving where it âlocatesâ itself in the spectrum
About the lighted switch, I get what you say, it is easier to locate the flashlight in the dark in a much better way! They also have it in other lights (E12R comes to mind, and others eventually).
As Lightbringer mentioned, I too preferred a different colour on the led indicator (red) but the fact is that it works as it is
The lighted switch is in my opinion the only thing missing on the T050R to make it perfect. I donât know if you like it as much as I do but what a fantastic wall of light, pur high CRI joyâŠ
Yup, probably one of the best lights I have too
That is a âbeastâ of a light! I am afraid of using it more giving it is almost a âpremiumâ light, but whenever needed, it comes out of the âlight-boxâ
And yes, an indicator LED could be good on it! Using a 21700, any parasitic drain would still make no harm on it!
BTW, I am not sure if Wuben uses the led indicator on the C3 and the C5 as well!
After checking Unheardâs thread reviewing the D1 I changed the information about the LED : it is a Cree XP-L HI 6500K instead of an Osram P8 or P9 as I initially suspected.
So far I wasnât able to remove the bezel and I am afraid that when I do that I will damage the host a little bit. Maybe I donât have the proper tools for it or the skills, but it is really stuck :weary:
If or when I can do that I will post it here referring to the method to retrieve it!
Tried and failed, too. I fear it needs heat, but optics and electronic components are close to the bezel. I think Iâll live with it. Itâs ok outside. Actually Iâm happy about every single candle I can squeeze out of it.
Thanks for telling your experience Unheard
Yeah, I suspect some heat would be needed, despite I also think that it can be some pressure downside up! But for that Iâd probably need to remove the driver and that may not turn good :weary:
