Looks like a compelling light, how does it compare as a thrower in terms of other modern flashlights? It seems a bit less SBT90.2 but high CRI? less throw than Osram but way more lumens, kind of like an angry XHP35 hi on its way to being a SBT90.2? lol
But will it work with 1 battery only?
If so, it would be cool to have it in M21C
I have 4X18A XHP70.2, I can compare those two on medium (both are ~ 1300lm) mode.
My batteries capacity in 4X18A and L6 should be roughly the same, ~ 50Wh
Runtime I will soon add a graph showing changing of brightness, now I have the temperatures, and also the brightness at minute 10. Temperatures: at 2 min: 40°C in the 5th minute: 43,5°C in 10th minute: 47°C brightness in 10th minute: 1657lm
Did you ever make a runtime graph? From the info above, it appears that the light drops to 50% output after only ten minutes.
1) Brightness drops after ~ 4 min, which is not the best result (but pretty common that flashlight drops brightness from Turbo quickly. After all, it is just "Turbo" which is meant to be a momentary mode), but keep in mind my measurements are done at home, when you use it outdoor, especially in cold (like at night) environment, the flashlight will sustain Turbo longer. Don't give me wrong, 4 min is not a long time, and that "longer Turbo" would be maybe 6, maybe 8 minutes.
2) Temperature increases further, after my 10 min threshold, stabilizing at 62°C at the hottest spot (at the bottom of the head) - measured in 70th minute
3) This runtime is ... well, just a runtime. The flashlight got very hot, and it's impossible to hold it: 62°C on the head, 55°C on the battery tube, and 53°C on the tailcap.
Received almost the same flashlight today. Only difference is 4000-4500K. Haven’t done any proper testing yet, but I did notice an interesting effect (apart from that the FC40 emitter is frigging huge!). When you turn it off, there’s an afterglow. And it’s not evenly distributed across the emitter, it’s more like a tiny snake game. Did anyone else notice this? It’s quite fascinating
PS, no I did not look into the beam, I noticed when putting it down on the floor. There was a clear circle visible on the floor. Don’t look into the beam, just don’t
May have to add this one… for tons of output the FC40 @ 4000k has become my favorite. I have it in 3 differently sized lights and would love it in a full on thrower. My old S70 cooked it XHP70 and I am considering repairing it, not sure I will with this option.
I just received my Convoy L6 GT-FC40 as well and love it. At first I didn’t think it was as bright as expected, but this is often my reaction to most lights I receive as I’m so used to my mega bright multi emitter lights. The second night out with it though is when I really was impressed wit it. For a single emitter light this thing is both a great thrower and flooder! The perfect all around light for backyard/ back acre viewing for when my pups are out late at night doing their business. Gotta keep them safe from the critters out here. Overall nice tint and very bright, but not so power hungry like some other emitters out there.
