✌ FREEME - LUMINTOP FW3X 2800lm Lume1 Driver AUX RGB LED Flashlight
Oh. Interesting.
Interested I suppose
Lumintoplighting has 3 colors in stock.
I was thinking the same thing :+1: , and if it could come with the new style 2way clip (the old style sucks) and in any other color than boring black…. :sunglasses:
It will have to be considerably less then $80 for me to buy. Still adding things up and trying to understand where they got that price.
Times are bad my friend... Factories cannot too afford to have too much unsold products in the inventory. I predict most flashlight manufacturers would scale down their collections or new releases in the coming months. I wouldn't be surprised if manufacturer announce their exit too. Hopefully, situation would improve by this July.
Yes please … very interested.
i can understand that.if no other colors become available and the price is ok i might still get a black one
freeme, could you find out if the flash pads have been corrected to the same positions as the standard pattern . (like noctigone/emisar)
Which glow tailcap are you guys talking about? Is it the one with trits in triangular formation?
Those bunnies are really nice.Whoa, i didn't know it is 9cm tall!
Send me a coupon when it’s ready please
It is same one for FWAA but only XP-L HI 1A available right now.
I was told them started FW3X assembly today.
I see, haven't seen these for quite awhile. Haha. I double check if it is compatible with this new light. Neal might have some stocks left.
In the FW3x you mean? I’ll hang in for the XP-L HI 3D
Interested
Has anyone else noticed a major, hard stepdown on Turbo mode on this model? I have the FW3A, FW21 Pro, FW X9L, FWAA but none of these models reduce their output within the first 3-6 seconds that much.
I have observed this behavior on two identical FW3X with XP-L HI V2 3A. Both lights were calibrated to 21°C room temperature when cold and to 55°C stepdown temperature. I used a fully charged VTC6 battery. The flashlight heads got barely handwarm after the first turbo run but significantly hot after several turbo runs.
According to my observation there’s either a hardcoded, timed output reduction after some seconds or the temperature sensing in the Lume1 driver seems to be oversensitive. Bottom line: Turbo mode seems more or less unusable in the FW3X and a big disappointment. :-(
if there was any other color then black… :person_facepalming:
Sent. [quote=Chinaheart]
Interested
[/quote]
Interested
Remove MCPCB and replace thermal grease...the cause of all my problems with stepdown
