Thrunite TN42 V2
Sorry to hear that Sarge12.
I just wrote to Thrunite and told them about their proprietary battery pack.Bad decision on their part. :person_facepalming:
I Never had and Never will buy a torch with proprietary battery.This one seems worse than the others.
This makes my TN42vn NW CFT90 look even better. :+1:
Regarding these batteries Not being on their website.This is a relatively New light.I would be willing to bet they will have them soon.It will be a money maker for them and a rip off for the general public, compared to 4 X 21700 batteries that we can buy.
Can the light be modified to support standard cells?
A lot of talented people on here I am sure some could.
The bulk of the members here and your average Joe Could Not.Me included.
So this light and the way Thrunite chose its battery pack is a definite negative for the average Joe.
No one should have to modify a light in order for it to work properly with standard batteries instead of Thrunites ,Under their mercy for replacement proprietary batteries that are always 2 to 4X more expensive than than loose batteries.
Yea these batteries are a deal killer. That sucks.
I wonder (if Thrunite was responsive to the community) a new upgraded carrier could be designed for this and sold as an accessory on there site? Would a differently designed battery carrier fix this “problem”?
Yeah I agree, horrible design decision.
As someone who holds a wide range of Thrunite products including the original TN42 and TN40 i find it disappointing that they have copied Olight by going the proprietory route. First it was the TT20 and now the TN42 v2….i personally refuse to support this practice
I also have several of their lights.
I will say this Eva Z. From customer service has always been helpful and have sent me FREE parts…holsters and a battery tube(threads stripped) for my TN42.
They have been more than fair and Very responsive and expedient at that.
I am interested to see how she responds to my email regarding TN42 V2 and its ill advised proprietary battery.
I’m still a little unsure that a special battery is needed. The way it sounds to me is the TN batteries have a bit of specialized construction with having pos/neg terminals on the button top end. Maybe that construction is for magnetic charging from one end one a special charger outside of this light. But the user said his Orbtronic protected cells did not work and unprotected Samsungs worked when magnet was put on top. Basically, what I’m hearing is that button top with tall enough button is all that is needed. Is this not the case, or does this light actually require a specialized cell beyond a sufficient button top on the positive terminal?
You have a point.Here is my Thrunite 26650 cell.Appears to have same construction .
That battery was for my Catapult V6.Orbtronic 26650 5750mAh Unprotected battery also worked.
It is the case that all that is needed is another button top protected battery with a tall enough button. The issue is that I have yet to find one. I think the removal of the plastic insulator which is held in the head with three screws might in fact allow the use of orbtronic protected button top batteries, but since that will kill my warranty I am reluctant to try. My question is, why should the purchaser have to modify a light to use readily available batteries? Why was the existence of this issue not made public in the advertising. I do not like the propritary nature of the olight batteries either, but at least there was a purpose for having the negative contact on the positive side for their magnetic charging and remote triggering. On this light, the negative area on the positive side only contacts a plastic insulator. It appears this was done solely to make the battery proprietary. Thank God I did not pay full price for this light, but I still feel the failure to point out other button top batteries like orbtronic will not work was disengenuous on Thrunite’s part. Had I been aware of the proprietary nature of the batteries, I would have passed on this light.
Those batteries do not have a negative contact on the positive side…totally different.
Ok…Could you post a picture of the battery so I know what it looks like?
Thanks…Yes I saw that on the website.Was hoping to get better pics of an actual battery…pics like I took of the 26650.
Look at the positive end, you can clearly see the metal ring that is a negative terminal.
In case you’ve never seen them before, many proprietary Li-ION cells do this to have both the + and - contacts on the same side.
It’s not that rare.
I can’t figure out how to copy a picture from my laptop…copy and paste does not work.
No it is not that rare, but none of the three similar proprietary batteries in these 3 pictures would work due to shorter center button. I think if I remove the pastic insulator held by 3 phillips screws and add insulators to the button side of these idiotic thrunite batteries both the thrunite and orbtronic protected cell might work. The plastic insulator ring is maybe a mm taller than the brass ring conductor. Therefore the button needs to be about a mm taller than the rest of the battery on that side. Otherwise the plastic insulator ring prevents the button from touching the brass conductor.
Update…removed the three screws that hold the insulator in the head and removed the insulator. Screws must be re-inserted because they also hold the PCB. Next I used plastic sticker insulators like those used for 18650 button top batteries when re-wrapping them, to totally cover the problematic negative washer on the positive side of the Thrunite batteries. With that simple mod of both the light and the battery, I can now use the thrunite batteries I further modified, or the orbtronic protected button top 21700 batteries. It is quite a simple mod if you have the right size battery end insulators. Both the Thrunite and Orbtronic batteries can also be charged in the light, or in a charger that charges 21700 protected batteries. Easy fix, but for a problem that should never have existed.
I wasn’t talking about these being replacements for the stock batteries, I was explaining how the negative terminal on the positive side can be obviously seen from the product picture.
