Compatible with 1-4 21700 Li-ion battery (not included).
USB Type C charging and discharging interface, supports PD3.0/PD2.0, QC3.0/QC2.0 fast-charging protocols.
Let`s save 10% on everything with FastTech sitewide coupon sale in April 2021! The discount code expires on 23:59 pm April 18, 2021( UTC-6)… No matter what you’re shopping for, you score 10% in savings on FastTech!
Date: Apr 17, 2021, to Apr 18, 2021 (UTC-6)
Offer: Site-wide 10% off
Code: MIDAPR10
Special notices:
The coupon code can not be used with drop shipping orders.
Site-wide offer valid: Apr 17, 2021, to Apr 18, 2021 (UTC-6).
This offer is not to be combined with other offers.
OVMS products are not included in this promotion offer.
3*Cree XP-G3 LED / 5-mode / 1400LM / pure white & RGB light / 1*CR123A/1*RCR123A/1*18350/1*16340 / clip / lanyard / IPX8
Head diameter: 26.8mm
Tube diameter: 24.5mm
Max Beam Intensity: 5260cd
Tail tactical switch + rotating control ring
1m impact resistance
Adjustable aperture size
Intellligent temperature control system to maximize the lifespan of LED
3*Nichia 219C LED / 5-mode / 1400LM / pure white & RGB light / 1*CR123A/1*RCR123A/1*18350/1*16340 / clip / lanyard / IPX8
1*Cree XP-L HI / 6-mode / 1000LM / pure white / magnetic USB rechargeable / magnetic tail / 105’ adjustable head / IP66 waterproof
Head diameter: 32mm
The Fenix WT25R rechargeable pivoting flashlight is specifically designed multifunctional workhorse for industrial maintenance and operations. What makes the WT25R special is the ability to angle the head of the flashlight up to 105 degree, allowing for multiple lighting directions. The pivoting head is perfect for hand-free use; you can either tail stand the light or use the heavy-duty body clip to hold the flashlight in your pocket. A third option is to attach the flashlight to a nearby metal surface with the magnetic tail. The WT25R features magnetic charging with the included 3400 mAh rechargeable Li-ion battery. The Fenix WT25R LED work light will become your favorite tool to use around the house or out in the field, especially for kinds of industrial workplace.
One Cree XP-L HI LED, with a lifespan of 50,000 hours.
1000 lumens maximum output and 220 meters maximum beam distance.
105 degree adjustable head for use at different angles.
Magnetic tail for hand-free use.
Magnetic charging with the included magnetic charging cable.
Battery level indication for instant checking of remaining battery level.
Lockout function avoids accidental activation.
Intelligent overheat protection against high surface temperature.
1-LED / 3-mode / 350LM / pure white / 1*18650/3*AAA
Working voltage: 4.5V
Head diameter: 37mm
Tube diameter: 37mm
Reflector diameter: 32mm
Light output up to 350LM
Beam distance up to 100-200 meters
Waterproof in accordance with IPX6
Can be used as self-defense bat in emergency case
