1*LED 6-mode 1000LM LED Headlamp
pure white / 1*18650 / Micro-USB rechargeable / IPX6 waterproof / angle adjustable / stepless dimming
JETBeam MINI-ONE LED Flashlight
1*Cree XP-G3 + 2*auxiliary LED / 7-mode / 500LM / pure white & UV & RGB / USB-C rechargeable / IPX8 waterproof (2m underwater)
Head diameter: 14.6mm
Tube diameter: 13.2mm
Temperature control technology
Automatic overheat protection
Wow! FastTech Mid-April 10% Site-wide Coupon Sale (starts on April 17th)
Dear Valued Customers,
Let`s save 10% on everything with FastTech sitewide coupon sale in April 2021! The discount code expires on 23:59 pm April 18, 2021( UTC-6)… No matter what you’re shopping for, you score 10% in savings on FastTech!
Date: Apr 17, 2021, to Apr 18, 2021 (UTC-6)
Offer: Site-wide 10% off
Code: MIDAPR10
Special notices:
The coupon code can not be used with drop shipping orders.
Site-wide offer valid: Apr 17, 2021, to Apr 18, 2021 (UTC-6).
This offer is not to be combined with other offers.
OVMS products are not included in this promotion offer.
JETBeam RRT03 Tactical LED Flashlight
3*Cree XP-G3 LED / 5-mode / 1400LM / pure white & RGB light / 1*CR123A/1*RCR123A/1*18350/1*16340 / clip / lanyard / IPX8
Head diameter: 26.8mm
Tube diameter: 24.5mm
Max Beam Intensity: 5260cd
Tail tactical switch + rotating control ring
1m impact resistance
Adjustable aperture size
Intellligent temperature control system to maximize the lifespan of LED
3*Nichia 219C LED / 5-mode / 1400LM / pure white & RGB light / 1*CR123A/1*RCR123A/1*18350/1*16340 / clip / lanyard / IPX8
JETBeam JET-1M GUARDIAN Tactical LED Flashlight
4*LED / 6-mode / 1200LM / pure white & red & green / 1*18650/2*CR123A / clip / lanyard / IPX8 waterproof (2m underwater)
Head diameter: 27.5mm
Tube diameter: 22.5mm
1m anti-drop height
Patent temperature control technology for overheating protection
JETBeam JET-U EDC LED Flashlight
1*Cree XP-G2 LED / 3-mode / 135LM / pure white / 1*AAA / lanyard / IPX8 waterproof (2m underwater)
Max Beam Intensity: 518cd
Adjust the brightness by twisting the head of the flashlight
1m impact resistant
Head diameter: 14.2mm
Tube diameter: 14.8mm
JETBeam E20R EDC LED Flashlight
1*LED / 5-mode / 990LM / pure white / 1*16340/1*CR123A / clip / Lanyard / IPX8 waterproof (2m underwater) / magnetic tail
Reflector diameter: 22mm
Head diameter: 26.7mm
Tube diameter: 26.7mm
Tail diameter: 23mm
Max Beam Intensity: 9600cd
1m impact resistant
Fenix E02R Mini LED Keychain Flashlight
1*Cree XP-G2 S3 LED / 2-mode / 200LM / pure white / Micro-USB rechargeable / IP68 waterproof
Head diameter: 15mm
Tail diameter: 14mm
Fenix TK16 V2.0 Tactical LED Flashlight
1*Luminus SST70 LED / 6-mode / 3100LM / cool white / 1*21700 / USB-C rechargeable / clip / lanyard / APF / IP68 waterproof
Advanced Pulse-Frequency Transmission System (APF).
Instant activation and strobe with the dual tactical tail switches.
Stainless steel strike bezel inlaid tungsten steel breaking tips.
6*Cree XPL-HD V6 LED / 7-mode / 6500LM / pure white / 1*21700 / lanyard / IPX8 waterproof (2m underwater)
SMILING SHARK E215-2 Mini LED Flashlight
1*Luminus SST20 / 7-mode / 1200LM / pure white / 1*16340/1*18650 / IPX6 waterproof
MATEMINCO CSF-04 USB-C Rechargeable EDC LED Flashlight
1*main LED+3*auxiliary LED / multiple modes / 300LM / pure white+blue+red+UV light / smooth ramping / IP65 / glow resinous material
HaikeLite MT09R LED Flashlight
3*Cree XHP70.2 / 7-mode / 25000LM / neutral white / 4*18650 / lanyard / IPX8 waterproof
Reflector diameter: 71mm
Head diameter: 74mm
Tube diameter: 51mm
Working voltage: 3.7-4.2V
Beam range: 600 meters
Mode: user-defined 6 group/22-mode + electronic electrodeless diming
Fenix WT25R Pivoting LED Work Light Flashlight
1*Cree XP-L HI / 6-mode / 1000LM / pure white / magnetic USB rechargeable / magnetic tail / 105’ adjustable head / IP66 waterproof
Head diameter: 32mm
The Fenix WT25R rechargeable pivoting flashlight is specifically designed multifunctional workhorse for industrial maintenance and operations. What makes the WT25R special is the ability to angle the head of the flashlight up to 105 degree, allowing for multiple lighting directions. The pivoting head is perfect for hand-free use; you can either tail stand the light or use the heavy-duty body clip to hold the flashlight in your pocket. A third option is to attach the flashlight to a nearby metal surface with the magnetic tail. The WT25R features magnetic charging with the included 3400 mAh rechargeable Li-ion battery. The Fenix WT25R LED work light will become your favorite tool to use around the house or out in the field, especially for kinds of industrial workplace.
One Cree XP-L HI LED, with a lifespan of 50,000 hours.
1000 lumens maximum output and 220 meters maximum beam distance.
105 degree adjustable head for use at different angles.
Magnetic tail for hand-free use.
Magnetic charging with the included magnetic charging cable.
Battery level indication for instant checking of remaining battery level.
Lockout function avoids accidental activation.
Intelligent overheat protection against high surface temperature.
Q5 Rechargeable LED Flashlight
1-LED / 3-mode / 350LM / pure white / 1*18650/3*AAA
Working voltage: 4.5V
Head diameter: 37mm
Tube diameter: 37mm
Reflector diameter: 32mm
Light output up to 350LM
Beam distance up to 100-200 meters
Waterproof in accordance with IPX6
Can be used as self-defense bat in emergency case
Fasttech New Arrival! 4-Head Full Spectrum LED Floor Grow Light w/ Timer for Indoor Plant
UK / US / EU Plug
96*red LEDs + 192*neutral white LEDs
height & brightness adjustment / w/ tripod stand
1*Cree XHP70.2 / 6-mode / 5500LM / pure white / 4*18650 / lanyard
Utilizes one American XHP70 2nd generation LED.
Exquisite,powerful,long throw.
Maximun output up to 5500lumens.
Built-in intelligent temperture control module can automatically adjust the brightness output.Keep using camfortably.
Built-in magnetic charging.
Reflector diameter: 81mm
Head diameter: 86mm
Tube diameter: 51mm
Beam range: 903 meters
