That diagram is rather intimidating indeed. I have yet to go through all the actions to date.
Wow. That is a scary diagram. I’m pretty comfortable with anduril but 2 is even more powerful.
Unfortunately, XPL-HI does not come in high-CRI. My current EDC is a modified DQG Tiny 18650 IV running Anduril with three high-CRI Nichia 219C as emitters.
This setup is quite a bit lower output than XPL-HI, but I like the tint, color temperature and CRI.
XP-L HI is available as high CRI. For example http://kaidomain.com/Cree-XP-L-HI-T5-7C1-Warm-White-3000K-CRI90-LED-Emitter
I just bought the sst 4000k version. Thanks freeme
Firelight2:Unfortunately, XPL-HI does not come in high-CRI. My current EDC is a modified DQG Tiny 18650 IV running Anduril with three high-CRI Nichia 219C as emitters.
That link doesn’t seem to work.
However, 3000K is too warm for me. I’d jump all over it if anyone finds XPL HI high-CRI at 4000K though.
Thanks, fixed the link. I’m not aware of anyone offering 4000K in small quantities.
Found some 4000K 90-CRI XPL available at Mouser.
But they aren’t high-intensity. They have the dome. They would need to use a modified optic or have their domes sliced to fit reliably in Carclo triple optics.
Also, I think shipping costs with Mouser are insane right now.
I would have been interested if it ran off actual AA Alkaline/Nimh and had a single emitter, current controlled. Then it would be a flashlight I could gift it to muggles.
The name should be FW3A Mini. FWAA is nonsensical and will disrupt the naming convention. Knowing Lumintop there will eventually be single-emitter and quad versions … now what are you going to call them?
I’ve gotten used to anduril 1 on all my lights, I also don’t like how getting to turbo is no longer 2c from on, instead it brings you to ceiling, which I can change to turbo but would just rather have all the lights I carry to be uniform in operation
I notice there were some questions about the length of the Vapcell H10.
I’ve ordered the Vapcell H10 a couple of month ago, both flat-top & button-top (unprotected), their measurements are as follows:
Vapcell H10 (flat & button-top unprotected)
Vapcell H10 flat-top @ 49.1mm:
Vapcell H10 button-top (unprotected) @ 51.4mm:
The caliper I’m using is not that high-quality, so maybe error could be +/- 0.1-0.2mm.
Thanks for the measurement d_t_a! :+1:
I measured:
Efest IMR14500 650mAh 9.75A (unprotected flat top) = 48.8mm
Shockli IMR14500 1050mAh 12A (unprotected flat top) = 48.9mm
Sanyo UR14500P 800mAh (unprotected flat top) = 49.1mm
Vapcell “Gold” ICR14500 1000mAh 3A (unprotected button top) = 50.8mm .
Vapcell H10 INR14500 1000mAh 10A (unprotected button top) = 51.3mm
interested in Nichia 4000K
Hey everyone,would someone please post the diagram for the Anduril 2 operating system. I lost the one I had,Thanks Jim
I guess you are refererring to this, last page:
[image] [image] It’s possible but the tolerances on the FWXX series lights are so tight that it could damage the spring or the cell itself over time.
Yes thankyou
Order placed for 2 with the sst20 4000k and a couple H10’s.
You could keep any eye on this thread also.
I did a major rewrite of Anduril. For a long time, I tried to avoid changing the UI much, and stuck to only small changes so it could keep backward compatibility. This was holding it back though, so I finally did all the bigger changes I had been avoiding. The new version is called Anduril 2. Current status 2020-09-30: Almost done; just finishing up a few little things. What changed? A lot: Uses a “simple UI” by default. This has only the core functions, like a normal flashlight — on (ramp),…
That’s where I got the UI diagram from.
Thanks for your help jim
Did you get button top or flattop
Interested in sst20 4000k
Interested: SST20 (4000K) LED
