The flat spots on the battery tube at 56.5mm, does anyone know of something that would fit that as is? Or know what size the one in the listing is (although a bit pricier then I would like)?
That would be a lot easier then making something custom.
Liionwholesale.com cancelled my last 2 orders. About 4 ish years ago I got in the Q8 buy and had them shipped but this last year and half No one is shipping up here I even went to some craptastic Vapecells for my 26650s.
Regarding the tripod hole, I guess I’m having a hard time understanding why the opposite side of the switch cannot work? If of course the fins weren’t milled out, and it remained a solid chunk of metal? Does leaving that as a solid flat piece effect the grip? It doesn’t seem like it would effect the battery tube?
EDIT: I just watched the video again, especially the first 20 second when they are rotating the upper showing the head and the button hole drilled out, the fins on the back really look like they’d have just enough meat, if left unmilled and flat, for the threading. But when millimeters matter using my eye does no good. I
I don’t have exact measurements but comparing it to my GT tripod hole, there does not appear to be enough room in those fins for the threads. The bottom fin is deep enough but the reflector inside the light starts expanding, that is why the upper fins are shallower. By the 3rd fin, there would not be enough room for sure as it is only a few mm deep. I am not sure how thick the metal behind the fins is but the CAD drawing does not look like it would be thick enough.
I did ask them to look into it though and they are but they are much more receptive to a handle that can be added to the light understandably. I told them if they make the handle custom that adding a tripod mount to it would be great. We will see what happens.
The issue I have had about doing reviews of my own lights is I could unconsciously look at them with rose colored glasses. This is why I try to keep my “reviews” on group buy lights I am running as fact based as possible to remain above any possible mis-representation.
I have no problems with others giving honest opinion based reviews which is why I am trying to get this prototype into the hands of someone that could do an unbiased review.
The usage of the light is identical to the GT70/90/94 as it uses the same firmware.
If I can find some time I might take some quick beamshots one of these nights and see how they turn out. I have about 10 projects going on at once right now (including building a barn that is a bit more work then I had planned lol) so have not had much time to sit still much less go take beamshots recently.
Ok, that makes sense; woth the expanding width of the inside cavity of the head, resulting in less substance for the tripod hole.
And I am not at all opposed to the style handle you, Yokiamy, and others had been mentioning. That seems like a completely reliable and reasonable solution to me. I would pay extra for that, depending on price. If it was included even better, but I’d rather see the price of the light stay down and just purchase a handle after the fact.
Thanks TA for explaining this to me and your patience with it. Can’t wait for this light!
