This is great info- about thermals, center of balance, etc. This light sounds solid!
I would be interested in testing/review of it. I could do vids as well. I have a better meter now I've been using for throw, as recommended by djozz - the Extech LT45, and even learned how to use it . I also have a set of Vapcell T50's I'd like to try out in this light, as well as T30's and T40's
Ohhh - didn't finish my post before bout reflector depth. Some manufacturers think they need depth for max throw, so they add quite a bit to the length of the light, which is mostly a waste. Unless you really like the reduced spill area, and probably more brighter spill, I don't see the point of added length for basically no gain in throw.
I would be interested in testing/review of it. I could do vids as well. I have a better meter now I’ve been using for throw, as recommended by djozz - the Extech LT45, and even learned how to use it . I also have a set of Vapcell T50’s I’d like to try out in this light, as well as T30’s and T40’s
Ohhh - didn’t finish my post before bout reflector depth. Some manufacturers think they need depth for max throw, so they add quite a bit to the length of the light, which is mostly a waste. Unless you really like the reduced spill area, and probably more brighter spill, I don’t see the point of added length for basically no gain in throw.
I will send you a PM about the prototype.
Yeah, I agree that depth is not required but also not opposed to having it, just kinda neutral on it lol.
I see what you’re saying about depth / vs. pure kcd benefit, makes sense. I guess I’d be neutral on it unless it added too much to the length of a light or really interferes with other design aspects. Good info I appreciate the explanation.
And I REALLY hope the prototype finds your doorstep. I think we would benefit from you having this light on your work bench. I know it’s helped me with other lights in the past. I’ll speak for myself, and I know others feel the same. Thanks guys.
Also- TA, any update about when We can PAY for this light? Lol. I have the money Burning a hole in my pocket :innocent: and I don’t mind the whole “group buy” aspect where you throw your money in the hat before production is done. If that’s an option, If not no worries.
After past experiences, I don’t do pre-pay anymore. Just too many possible issues and very little upsides.
They are supposed to be ready to go live with the listing in around 2 weeks depending on the china holiday that is going to shut china down for a week or so next week I think.
Understandable, I have a tendency to get ahead of myself so good call. Thanks for heads up.
The prototype is officially in the mail on the way to TomE for a more in depth review with beamshots!
Look'n forward to seeing it!
awesome !
Added the manual for the light to the second post
I do like deep (but not extremely deep) reflectors. While spot brightness is not affected, some of the spill that is in shallower reflectors is in deep reflectors converted into a bit wider hotspot, which is where I find the light more useful than going to the side.
This Wildtrail light, from what I can see, has about my ideal reflector depth.
i am getting very excited for this WT90, specifically because i got my MF02sV2 delivered last night, which is an awesome light. And this WT90 (i believe) will trump the mf02sV2, based on the reflector width (74mm vs 90mm), battery type (3 30t’s or 40t’s!), and design for thermal capabilities. I mean i could be wrong, and i really like my mf02sV2, but i see this WT90 being on a whole different level while being close to the same size. which is exciting.
Oh, and plus the WT90 has Narsil UI, which is just MUCH better then the stock Astrolux UI, i think most of us would agree. lol.
If they are ever mass produced, I am in for one of each color.
That MF02S v2 rating of 6500 lumens is way out there. I see Flashaholic got more reasonable #'s, think 4800 at 30 secs, 5600 at turn on. I'm even surprised it got 5600 lumens at turn on - that's impressive for a SBT90.2 in a factory stock light.
I'm assuming the short MF02S v2 has 4 parallel cells?
I agree, 5600 lumens is very nice. My Noctigon K1 SBT90.2 was 5,100 lumens at turn on and I know Hank pushes the envelope for sure.
Interested in a silver one.
That MF02S v2 rating of 6500 lumens is way out there. I see Flashaholic got more reasonable #’s, think 4800 at 30 secs, 5600 at turn on. I’m even surprised it got 5600 lumens at turn on - that’s impressive for a SBT90.2 in a factory stock light.
I’m assuming the short MF02S v2 has 4 parallel cells?
2S2P
I agree, and i’ve shared this before, but i’ve come to reign in my expectations on the lumens of the sbt90.2 (just because i’ve seen enough reviews on these lights online and their lumen ratings form members like Matt smith and flashoholic) that it is much more realistic to achieve 4200-5000 lumens, or so it seems. Like with Lumintop and astrolux specifically, claiming 6500 lumens, it just seems like when they’re tested by end users they dont achieve that, stock that is.
The mf02s V2 looks like 2s2p, (2 batteries facing positive up, 2 facing positive down), so i think thats what that means right?
Also, when i do “battery check”(5 clicks from off, iirc) it counts out up to “8, 4” with flashes on the button light. So… 8.4 volts of course.
I am Interested in a silver one please,
what a Great design - it is a Beautiful light!
Why wait until then? The price will be higher at that point?
Also, “mass production” is a relative term, they don’t plan on kicking out a 1000 of these like larger companies. This group buy will really set the tone for how many they make long term. It will remain for sale after the group buy though.
