So after of before the LDO it works, also when powered by another source e.g. the battery. Mike already mentionned it but with the LDO I wanted to test to be sure.
Good to know! I haven't experimented much with it, but ElTangas says that as long as the VCC at the MCU is ~60%+ of the programmer's voltage, it should work just fine.
I just pushed a few changes to my Anduril2 branch:
Switched to 10 MHz clock and Phase-Correct (dual slope) PWM instead of Fast (single slope) PWM at 5 MHz. This results in the same effective PWM speed: 19.6 kHz in the upper ranges, down to 4.9 kHz in the lowest modes (due to the dynamic underclocking mechanism).
Added some documentation to the PWM setup code including a some instructions and a link to the datasheet
Instead of Factory Reset forcing a thermal offset to assume an ambient temperature of 21°C, a Factory Reset for the 1-Series will clear any user-set thermal offset since the internal sensor is factory calibrated.
phase correct allows for full on and full off PWM, are there other advantages ? For drivers where we use the filtered PWM signal it’s not really an issue to have 1/resolution-1 as the min/max, and running the MCU slower saves power so if there are no other advantages then fast PWM is preferable.
I’m not aware of other benefits, it’s mostly to just get the Full-On and Full-Off signals.
For the drivers with a filtered PWM signal, you can still use Single Slope (Fast) when setting up the PWM in hwdef. And in the config file, just set the QUATERSPEED_LEVEL and HALFSPEED_LEVEL really high so that the MCU is running underclocked most all of the time. At least that’s the easiest thing I can think of at the moment.
Another question :
Is it possible to change the internal reference voltage in the hwdef file ? Using 2.5V instead 1.1V allows to use a divider with the same values, it’s a small detail but reducing the amount of different resistor values is always a good thing.
Not without some code modifications. In “fsm-adc.c” you’ll see a reference to VREF_ADC0REFSEL_1V1_gc. For a one-off build you could change that value, or the code could be updated to read that register from a #define … but that’s still a code change, simple though it may be.
Yeah I saw that line but I imagined it might need some change to allow to do it in hwdef. We’ll I’m already using modified Anduril files so I might as well change it in fsm-adc.
Thanks.
Ugh. Thankfully my Mouser order I placed in February is en route to Mouser (from the manufacturer) with the expectation for it to ship in July. Fingers crossed.
